Stuck oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2009, 11:06 AM   #1 (permalink)
View mr_tyrone's Photo Gallery
Stuck oil filter
Does anyone know how to remove a stuck oil filter? the black rubber coating in fram filter melted, so the socket i'm using doesnt work anymore. and can i remove the filter without removing the oil?
mr_tyrone is offline   Reply With Quote
Old 05-01-2009, 01:47 PM   #2 (permalink)
Cman46290's Avatar
View Cman46290's Photo Gallery
Some oil will come out when removing the filter... but not all... you will need to top off the oil after taking the filter off.... as far as getting it off.... just use a gorilla grip with your hands and turn it off... or take a pair of oil filter pliers and get it off....
-Corey
2005 Corolla XRS
Fujita F5 SRI
Cman46290 is offline   Reply With Quote
Old 05-01-2009, 01:50 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Strap wrench.
mikered30 is online now   Reply With Quote
Old 05-01-2009, 02:39 PM   #4 (permalink)
View johnoh's Photo Gallery
punch a long screwdriver through it laterally near the bottom. Then just turn the screwdriver
johnoh is offline   Reply With Quote
Old 05-02-2009, 12:14 AM   #5 (permalink)
View adrianm413's Photo Gallery
strap wrench works wonders
adrianm413 is offline   Reply With Quote
Old 05-04-2009, 11:59 AM   #6 (permalink)
Banned
View bbsgarage's Photo Gallery
I wouldnt use the screw driver through the filter trick, because if it is really stuck, you will simply tear up the filter and then you are really screwed.
Use a strap or clamp-on type of wrench.
bbsgarage is offline   Reply With Quote
Old 05-13-2009, 07:06 AM   #7 (permalink)
View 02zx9r's Photo Gallery
I have had to use the screwdriver/hammer method around 4 times in my lifetime, It has worked for me every time.
But like bbs said, you potentially can really screw yourself *IF* it doesnt work.
02zx9r is offline   Reply With Quote
Old 05-13-2009, 07:31 AM   #8 (permalink)
View rsirois's Photo Gallery
I've had the screwdrive/hammer method fail on my 86 Dodge Colt. I tore it in half with the screwdriver. The cure was to remove most of the front bumper and grill so I could use a pipe wrench on the thick metal piece at the bottom. It was a 16 hour day and I think it would be worse on a Corolla as the filter is in an inaccessible place.
Spend a few bucks on a strap wrench and only hand tighten when putting it on so you can remove by hand the next time. After my incident I stopped having the oil done because oil change places put them on too tight.
What happened to cook off the Fram coating? I've used them since they came out because the filter is much easier to remove. I've never had one melt.
rsirois is offline   Reply With Quote
