turning ingnition problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2009, 11:58 AM   #1 (permalink)
View ladyofluck's Photo Gallery
06 corolla ce.
well, when i'm turning the key to start the car, it sometimes doesn't start like it used to. Normally, it would crank 3~4 times then engine would start with abrupt high rpm then immediately goes steady 24~25k?
but sometimes, it would crank for 6~8 times. and then engine starts w/ low rpm about well below 21k? then work it's way up to 24~25k? steady.(in about 1~2 secs)
and sometimes it would crank normally but the rpm doesn't kick up like it normally did.
maybe premium gas isn't right for corolla? or maybe air filter is dirty?(it's cold air intake also.. AEM brand)
thx. : )
ladyofluck is offline   Reply With Quote
Old 05-08-2009, 12:03 PM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
No, don't use premium fuel. Read the owner's manual -- it'll tell you everything you need to know. Regular fuel (87 octane) is the fuel to use. Aftermarket intakes can cause problems as well, especially if oil from the filter gets on the MAF sensor. I would recommend ditching the filter if you have an oiled type and get an AEM Dryflow filter. It's dry...you don't have to oil it.
JasonA is offline   Reply With Quote
Old 05-08-2009, 12:14 PM   #3 (permalink)
it is AEM dry filter.
and about Premium gas, wouldn't I benefit more gas mileage and maybe more power from Premium gas? also maybe healthier for the engine ?
Old 05-09-2009, 08:42 PM   #4 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
No, a common misunderstanding. the higher octane grades of gas do NOT equate to more power potential, they only reduce the risk of pre-ignition/detonation in higher compression/performance engines, that's ALL.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 05-12-2009, 11:15 PM   #5 (permalink)
The Pwnstar
shadowtag88's Avatar
View shadowtag88's Photo Gallery
you could put regular in a car that needs premium as long as you dont rev it high too. its all dependent on the compression ratio.
but i have heard a friend say his car needs regular. but if he uses medium grade, hell get better gas mileage.. so it turns out to be cheaper for him to run that... but thats what he says...
how many miles on the car?!
check pcv valve, idle air control valve? im not positive how these corollas are.. air filter?
my guess would involve a vacuum hose somewhere....
shadowtag88 is offline   Reply With Quote
