Looking for led tail lights? 2005 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2009, 08:51 PM   #1 (permalink)
Canibe's Avatar
View Canibe's Photo Gallery
Canada Looking for led tail lights? 2005 Corolla
Couldn't find a real good post for led tail lights.
I was wondering if anyone had experience with led bulbs or even led light assemblies.
Also was wondering how they are? Did they live up to your expectations?
If anyone has pictures or anything to do with led lighting please post.
Thanks
Canibe is offline   Reply With Quote
Old 05-11-2009, 06:31 AM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
I'd skip the LED bulbs, but LED housings (OE) are available for our cars. Scour eBay for "1st gen altis tails" or "2nd gen altis tails". The 1st generation Altis tail lamps have a circular LED array, and the 2nd generation Altis pieces have a more horizontal array. I'm always looking for a set of the 2nd gen Altis tails on the cheap.
JasonA is offline   Reply With Quote
Old 05-11-2009, 10:11 PM   #3 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
I picked up a set of drop-in bulbs from autozone for like $17. work fine, I wasn't trying to change the look but rather get the extremly long life span. plus they hardly pull any current, but thats of little use if your cars on. I think that they were 3157 bulbs.
Rdkill is offline   Reply With Quote
Old 05-12-2009, 02:36 PM   #4 (permalink)
The Pwnstar
shadowtag88's Avatar
View shadowtag88's Photo Gallery
or here for 10 dollars...
http://store.newlevelmotorsports.com/3157ledbulb1.html
shadowtag88 is offline   Reply With Quote
Old 05-12-2009, 09:22 PM   #5 (permalink)
Canibe's Avatar
Pic's
Does anyone have pics of what they look like at night? even compared to stock?
Is there any interference if i replace the signals too?
I have a 2005 corolla ce se manual tran
Old 05-13-2009, 05:11 PM   #6 (permalink)
10' Corolla S
I'll give you a pic when its dark here tonight...dont do the turn signals unless you switch to an electric flasher, as strange things may happen since LEDs work so different compared to incandescent.
You might be able to get away with just replacing the front turn signal bulbs...but both could cause random/slow/rapid/inconsistant flashing.
Old 05-13-2009, 05:58 PM   #7 (permalink)
View rsirois's Photo Gallery
I tried a set of 30 led bulbs I bought on Ebay. They were too dim to leave them in. If you buy a set make sure they deliver the same lumens as a standard bulb.
rsirois is offline   Reply With Quote
Old 05-13-2009, 08:46 PM   #8 (permalink)
10' Corolla S
Here are mine....they're DOT approved so they must be bright enough....
Lights On (LED on Right)
Brakes (LED on right)
Comparison (Normal Left, LED right)
Close up of LED
Theres not too much difference directly behind, but the leds are more focused, overall light output seems similar.
They do make more expensive Leds that have side mounted leds to disperse light more into the reflector but they're generally not needed for Leds as they are focused internally. But here the stock reflector still reflects some light.
Old 05-13-2009, 09:01 PM   #9 (permalink)
Canibe's Avatar
sweet thanks
Old 05-15-2009, 09:51 PM   #10 (permalink)
caddymac's Avatar
View caddymac's Photo Gallery
I picked up some LEDs years ago for my old Nissan from www.superbrightleds.com . Not sure if they are still around, but they seemed to do the trick.
caddymac is offline   Reply With Quote
Old 05-16-2009, 04:13 AM   #11 (permalink)
Si no moar!
jaysi09's Avatar
View jaysi09's Photo Gallery
IMO, if you have money to spare. Opt for the LED housed taillights.
here's pics of Altis 1st Gen LED tails.
jaysi09 is offline   Reply With Quote
