Air control problems...especially when cold
Hi folks...need some suggestions here.
It's an '06 Corolla, and has a recurring problem: The control in the middle of the dash that regulates airflow (passenger,feet, defrost, etc.) has failed repeatedly. Sign of failure: it requires a lot of force to turn it to the defrost mode. It's been serviced probably 4-5 times for the problem, including lubing the cable, replacing and lubing the cable, and (according to the dealer) finally replacing the assembly. Now even on a slightly cool morning, it requires some effort to force it into the defrost mode. AFTER the car is warm, it turns easily. OK, so the problem is not the effort to turn it to defrost, but that the control then stops working. That is, the control turns easily but no longer regulates airflow.
We have an extended warranty which may help. Any with with similar experiences or solutions...? Suggestions will be appreciated.
Thanks - Ken
 Ken
