alright here we go.
number one.
DO NOT START UNBOLTING CRAP. thats how people get hurt especially when working with struts.
step1: jack up the car, secure it with jackstands, whatever. make it safe to work on.
step2: remove the wheel
step3: unbolt the strut from the hub assembly. -be careful with any brake lines or abs sensors.. and all that stuff. support the control arm with a jackstand or somethign so it doesn't fall.. but you don't really have to i suppose.
step 4:with the hood open, unbolt the three bolts around the strut tower DO NOT LOOSEN THE CENTER NUT.
step 5: remove the strut/spring assembly from the car, attach the spring compressor to the spring... compress it..
step 6:remove the center nut that i said not to remove before.... only after you are sure the spring compressor is securely holding the spring.
step 7: remove the top hat, slide the spring out, and slide the new lowering springs on. make sure the new spring goes on in the same positon the original spring came off...
step 8: put it all back together... making sure you use the correct torque requirements.
its pretty simple. but the scary part is the spring compression part.. some people like to have a shop do that for them.. even if its just takign the strut/spring assembly there and having them swap the spring out.
when you have everything back together, get an alignment.
cheers!
