Rim Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2009, 06:45 PM   #1 (permalink)
05 Rolla
View RawDarkness's Photo Gallery
Rim Help
I want to lower my car 2 inches, I have the springs and right now I have the stock rims (15 in) and I want to get rims that are 17 inches but was not sure if I should get the rims first then drop the car, or does it even matter what order I get them.
I want to make sure that the 2 inch drop won't affect 17 inch rims, or should I just got to 16?
RawDarkness is offline   Reply With Quote
Old 05-12-2009, 09:53 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
find a set of 17s that you like, post up their specs and then we can tell you if the drop will affect them. most likely, you'll be fine, a 2" drop is not that drastic.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 05-12-2009, 10:29 PM   #3 (permalink)
Adama's Avatar
View Adama's Photo Gallery
It really depends on the rims and what offset they have. To give you an example, I'm dropped 2” (H&R race springs) with 09 Corolla Xrs 17” X 7” rims with 40mm offset and 225/45-17 which keeps the speedo at the factory settings and no rubbing.
H&R Race Springs / 09 Xrs Rims / TRD F & R Sway Bar / TRD FSB / Alutec RSB
Avic Z3
/ Tc Center Armrest / Tc HomeLink Mirror / Valentine 1 / ScanGauge II
Adama is offline   Reply With Quote
Old 05-12-2009, 10:57 PM   #4 (permalink)
The Pwnstar
shadowtag88's Avatar
View shadowtag88's Photo Gallery
if you get 17 inch rims. it should not matter.
but this fact is dependent on a few things.
the best way to do it is get rims that have the same offset as stock. this will prevent the rims rubbing on the caliper.
as for tires. you would ideally and get a tire that is exactly/ closest/ within 3% of the stock tire height.
this will prevent the need to adjust your speedo. and the smaller sidewall in the tire will improve handling.
stock sizing is 195/65R15
if you were to get 17 inch rims you would want something like 205/50R17 which will only show the speedo slower by .3 mph
here use this http://www.1010tires.com/tiresizecalculator.asp
you can make sure you get the right size rim as well.
good luck.
shadowtag88 is offline   Reply With Quote
Old 05-13-2009, 12:22 PM   #5 (permalink)
05 Rolla
Thanks! Thats helped so far.
Here is the link to the rims:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
17" x 7"
Offset - 38mm
Backspacing - 5.57"
Tire Size - 205/50-17
Will this work?
Old 05-13-2009, 12:40 PM   #6 (permalink)
The Pwnstar
hmm that link just took me to one of tires racks main pages not a specific wheel. but im not certain on the stock offset. i have steelies on the corolla i drive and dont intend on modding. the stuff i said was just general info on wheels.
the poster above me might have better info. he has wheels and tires on his car... hes even got wider tires than what i suggested. which would inprove the handling a bit more too.
or you could call up tire rack or something. i think theyd be able to give you a definitite answer
Old 05-13-2009, 12:43 PM   #7 (permalink)
05 Rolla
I just checked the link since you said that,,,ya that sucks it takes you to the home page. hmm
I think I may just go to a shop around me and see what they think is best for the car
Old 05-13-2009, 06:49 PM   #8 (permalink)
Adama's Avatar
Here is another great wheel calculator. You can compare different tire sizes and rim sizes and see how much closer to your suspension, how much farther the tire will stick out and the different in the speedometer.
Avic Z3
Old 05-13-2009, 08:50 PM   #9 (permalink)
on full afterburner
Gameroom cash: $1346597
Most wheel shops don't know squat anyways about proper fitment.
I would rather do my own research than have somebody tell me what they think is best for my car!
Seriously dude, to me you're just begging to be ripped off right now.
