would these rims fit if my car was lowered?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2009, 01:59 PM   #1 (permalink)
View impulseRED's Photo Gallery
i was wondering if these rims would fit....
Konig Feather - Black 17" x 7.5" - 5/100 - 45mm
with my 2005 corolla s lowered 1-2 in??? any imput would be greatly appreciated
also what tire sizes would rub on my car???
also any tire tips would be nice aswell
impulseRED is offline   Reply With Quote
Old 05-14-2009, 01:25 PM   #2 (permalink)
on full afterburner
Gameroom cash: $1346597
not sure what the stock offset for the 9th gen is.... if an owner would chime in with this
but that offset looks a bit high for the width you selected, which might result in rubbing on the strut
I would go with something with a lower offset closer to +40 just to play it safe.
Old 05-14-2009, 04:18 PM   #3 (permalink)
te offset is 41 stock and the rims are 40
Old 05-15-2009, 12:24 AM   #4 (permalink)
Si no moar!
jaysi09's Avatar
View jaysi09's Photo Gallery
stock offset for the rolla's are +45/
IMO keep the offset around +40 just to be safe.
and for tires, 225/45/17s are the common size tires for 7.5 width.
jaysi09 is offline   Reply With Quote
Old 05-15-2009, 07:21 AM   #5 (permalink)
on full afterburner
you have to take into the account of the extra width in the new wheels, so if you stick with the stock offset then you will run into problems with rubbing the suspension components, and this is impossible to correct other than getting a net set of wheels.
you will want to go lower to push the wheels out to the fenders, if you run into problems there, it's only a matter of rolling the rear fenders and maybe doing some pulling in extreme cases, but all in all, an easier problem to correct than installing close to stock offset wheels.
Old 05-15-2009, 08:36 PM   #6 (permalink)
well thanks for your time every1 im going to try to make the best decision i can about the rims im going to get,
still thinking about the feathers but the konig black bumps look nice
