Headlight Haze - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2009, 03:55 PM   #1 (permalink)
View brad_i2001's Photo Gallery
Headlight Haze
What would you guys recommend for cleaning hazing headlights? I have to keep my car outside, and it is starting to haze the lights where the hood bends. There are several products at the store, but I was wondering what you would suggest as the best. The space that needs to be polished is fairly small, but right over the main beam. I would just feel better if it looked like I took care of my car better.
Thanks!
brad_i2001 is offline   Reply With Quote
Old 05-17-2009, 07:22 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
meguiars plastix and alot of elbow grease. Put a good wax or sealant on it when done.
mikered30 is online now   Reply With Quote
Old 05-17-2009, 08:24 PM   #3 (permalink)
on full afterburner
Gameroom cash: $1346597
+1 on the meguiars plastix.... I usually apply it and leave it on for half an hour then remove it with a microfiber using lots of pressure
Old 05-17-2009, 11:55 PM   #4 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
wetsand with 2000 or 3000 grit sand paper (the higher the grit the finer the scratches) and then use Plast-X by Meguairs.
Plast_X is similar to Scratch-X but made for plastic material which is what your headlights are made of.
Afterwards use a good wax to protect it, you may have to do this from time to time though.
XR2003 is offline   Reply With Quote
Old 05-18-2009, 08:11 AM   #5 (permalink)
'11 Camry
View JasonA's Photo Gallery
The only thing I've had success with is the 3M kit. I did it on my Dakota truck.
Before:
After:
Comparison:
JasonA is offline   Reply With Quote
Old 05-19-2009, 09:32 AM   #6 (permalink)
GO KING'S GO!
dktaco's Avatar
View dktaco's Photo Gallery
Porter Cable dual action polisher with an orange pad and my personal choice XMT #3 polish. When done polishing use a microfiber towel to wipe off. Then spray Plexus to protect them and wipe off.
dktaco is offline   Reply With Quote
Old 05-22-2009, 08:40 PM   #7 (permalink)
Thank you guys SO much! I bought the Maguire's Plastix kit with the drill bit and cloth, so I plan to take care of this next weekend.
Thanks Again!
Old 05-30-2009, 07:01 AM   #8 (permalink)
View cor06's Photo Gallery
Jason- the cleaned (treated) lights looking amazingly clean, what is this 3M kit, I mean what I should be looking for at autozone or advance auto parts. I need to clean the lights on old car.
Thanks
cor06 is offline   Reply With Quote
Old 05-30-2009, 07:50 AM   #9 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Fine grit sand paper, powerball mini + polish or plastx
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 06-01-2009, 07:26 AM   #10 (permalink)
'11 Camry
I got it at AutoZone. $19.99 I think. Here's the exact kit:
http://www.amazon.com/3M-39008-Headl.../dp/B001AIZ5HY
P.S. where are you in NC? I'm in Fayetteville.
Old 06-20-2009, 03:46 PM   #11 (permalink)
04 XLE Limited
View xmateo's Photo Gallery
I believe I used a 1600 or 2000 grit sand paper. It looks worse now, and the Meguairs didn't help. Did I scratch the surface too much? Is it still salvagable?
Don't think I saw 3000 grit at the hardward store. I just used the sandpaper while continually pooring water over the surface. Is this wrong? Helpful hints?
xmateo is offline   Reply With Quote
Old 06-20-2009, 04:40 PM   #12 (permalink)
Xmanteo, buy the power ball that comes with the plastix. That thing did the trick for me. Also, if you made the scrathes too deep, you can get some replacement headlights from k2motor for about $100. I will try to help you, just post some pics and we can decide from there.
Old 06-24-2009, 01:21 PM   #13 (permalink)
'11 Camry
The 3M kit includes everything you need, including the polishing wheel that you chuck into your drill. It's really the only thing I've tried that gives really good results. It's the last time you'll spend money on restoring headlights.
Old 06-25-2009, 02:26 PM   #14 (permalink)
The Pwnstar
shadowtag88's Avatar
View shadowtag88's Photo Gallery
+1 on that 3m kit. it worked GREAT. be sure to spend a good amount of time on it though.. i rushed it on one side.. and i think i made it milkier.. but clearer.. i cant explain it.. just make sure you take your time doing this..
shadowtag88 is offline   Reply With Quote
Old 06-27-2009, 02:00 AM   #15 (permalink)
04 XLE Limited
Thanks. I will look into this... and thanks for the hints.
