Newly installed aftermarket radio cannot receive AM channels
I recently installed an aftermarket CD/radio on my 2004 Corolla with the standard fitting and harness wiring. The radio is Pioneer 2100. Everything works fine except the AM radio signal is very very weak. Even for local channels I can barely hear the channels. I took the radio back to Bestbuy, they tested on their demo panel it worked fine. I put the original stock radio back and that worked fine too.
With the original stock radio, it does not have a dedicated ground wire, the ground wire is in the plug. Therefore I connect the Pioneer radio ground wire to the black ground wire from the harness. Antenna plug fits into the new radio very well. Anyone have any idea why the AM radio does receive good signal?
Reason: incorrect word
