Rear brakes (minimum thick. and creaking sounds) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2009, 10:26 PM   #1 (permalink)
View burnt03's Photo Gallery
Couple questions about my 2003 Corolla.
1) What is the minimum shoe thickness?
2) The right rear brake creaks/squeaks after I let off the pedal. Haven't taken it apart yet, but what do you figure?
Thanks in advance!
1990 Corolla SR5 (Mine)
2003 Corolla CE (Wife's)
burnt03 is offline   Reply With Quote
Old 05-24-2009, 10:37 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Standard 4.4 mm (0.173 in.)
Min 1.0 mm (0.039 in.)
Might need to adjust star wheel on back of drum. Do you backup at all?
mikered30 is online now   Reply With Quote
Old 05-25-2009, 07:58 AM   #3 (permalink)
Yep, at least 1-2 times a day.
Last time I checked the shoes they were about 2mm, so I guess it's time to change them out. When I'm in there maybe I'll be able to find what's causing the noise.
Thanks for the info!
Old 05-25-2009, 09:00 AM   #4 (permalink)
View jonjoe's Photo Gallery
i think the handbrake mite be rubbing causing the squeaking happened in my 05 try adjust your handbrake by the star on the back brake drum...should between 6to 9 clicks i put mine at 7 and the squeaking stopped worth a try....
jonjoe is offline   Reply With Quote
Old 05-26-2009, 07:40 AM   #5 (permalink)
'11 Camry
View JasonA's Photo Gallery
The squeak is likely the brake shoes rubbing on the brake backing plate. Check for wear there, and use a small amount of wheel bearing grease (just enough to lubricate that surface, but not enough to contaminate the braking surface of the shoes or drum).
JasonA is offline   Reply With Quote
