Audio Setup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2009, 06:02 PM   #1 (permalink)
View yosemitesam's Photo Gallery
Audio Setup
i was wondering about the audio setup in my car. 03 corolla le - it has 2 front + 2 rear and 2 tweeter. Are the fronts ones woofer + tweeter or a 2way with a tweeter. And is there a crossover or anything in there somewhere. Someone please explain me how this works
Thank You in advance
yosemitesam is offline   Reply With Quote
Old 05-29-2009, 07:47 PM   #2 (permalink)
Old Fart
mmasse's Avatar
Gameroom cash: $261903
View mmasse's Photo Gallery
ok it was moved now
mmasse is offline   Reply With Quote
Old 05-31-2009, 11:08 PM   #3 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
Well the stock stereo is 4 channel...so this would mean there must be a crossover somewhere....most likely the tweeters run off the front channel through a crossover since they use so little power. So the tweeters and the font speakers are getting the same signal.
There are no two way speakers in the corolla, there wasn't in mine anyways...
2010 Corolla S, stock(for now )
Gone
-08 Corolla S 5 Speed- A silverish color
Intake, Lights, STB - Ported & ploished - 35+Mpg
Rdkill is offline   Reply With Quote
Old 12-21-2009, 02:59 PM   #4 (permalink)
View the4starish's Photo Gallery
I know this is kinda an old topic, but i didnt think it would be appropriate to start a new one. My question is about the possibility of a crossover. I have an 06 with the 6 speaker setup. If there were to be a crossover, where would it be? Also, how are the tweeters wired into the system? Is it directly to the headunit? or does the headunit shoot off four channels and then they are split at the tweeter / woofer?
EDIT: OK I re-read what Rdkill said and now i get how the tweeters are wired. But I still dont know where the crossover is. Any help on that would be appreciated. Essentially I want to add a new system with its on crossover and i want to make sure i remove the old one so it doesn't interfere with the new one.
the4starish is offline   Reply With Quote
Old 12-21-2009, 05:20 PM   #5 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
There is no crossover. All frequencies are sent to the large speaker in the bottom of the door, and there is a filter on the tweeter to cut out the lower frequencies.
There is a 4 channel output from the headunit. It is split in the door (simple wire splices) with one going to the large speaker, and one to the tweeter with the filter attached. If you look at the tweeter you'll see what looks like a small capacitor soldered onto it. That's as close to a crossover as most all stock 6 speaker setups get.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 01-04-2010, 01:15 AM   #6 (permalink)
View sirbelch's Photo Gallery
well, how would you install a component speaker set in the fronts if you have the 6 speaker set up?
sirbelch is offline   Reply With Quote
Old 03-07-2010, 08:37 AM   #7 (permalink)
New 2 Toyota
View Stefan2k's Photo Gallery
Question What did you do?
I saw your post about the front speakers in your car, so i was wondering what happened since I'm about to install a 6.5 inch component system in my 07 corolla. How did you get to the tweeters in the door and was there much modifying?
Stefan2k is offline   Reply With Quote
Old 03-07-2010, 10:23 AM   #8 (permalink)
What i did was take the wired coming from the stereo to the woofeer at the bottom and connected it to my crossover and then wired my speakers from the crossover
Old 03-07-2010, 08:20 PM   #9 (permalink)
New 2 Toyota
Ok Im cool on the wiring, but I saw a lot of picture from people who said they had to cut up the old midrange/woofer and use it to make a spacer. I'm cool with that too, but I'm wondering about how the tweeter install went? and how to remove the door panel without messing anything up?
