Originally Posted by ladyofluck
oh, and why is the transmission so sluggish on Corolla AUTO?
My 88 Camry did better in switching gears. very quick and snappy. Especially with that ECT button, the car would switch gear like snap!! down/up shift, either one would be very quick.
But Corolla would shift up like if the gears were made out of marshimellows. I want my ECT button on Corolla!!
oh... and it's very hard to pass someone at awkward speed like 50km/h. gear wouldn't shift down to it's optimal RPM, and would just stay on high gear..
Camry was slower though, just not enough power.
1st) it's an automatic, 2nd) it's a four cylinder, 3rd) the reviewer must've used a different version of the Corolla to test, 4th) it's an economy car.
You can try to give the car a tune-up: spark plugs, oil change, check the air filter. Another thing you can do is engine braking. While stepping on the brake, press down a little on the gas until the rpm is at least at 1500rpm. After that, just let go of the brake when your ready. I don't recommend doing it alot though since it can hurt the engine mounts later on in the future. There's no ECT button on the Corollas?
