throttle doesnt work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2009, 09:43 AM   #1 (permalink)
View Acosta1990's Photo Gallery
my throttle on my 05' corolla doesnt work ..its automatic and when i put in reverse or drive the car jumps and the check light is on....does any one know what is wrong
Acosta1990 is offline   Reply With Quote
Old 06-01-2009, 10:20 AM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
You're going to have to give us some more detail. Is the engine running at idle, in park? What is the RPM? If you press on the gas pedal, does the engine speed increase? After you put it in gear, and the car "jumps", what next? Does the engine die or keep running? Can you drive the car at all?
JasonA is offline   Reply With Quote
Old 06-01-2009, 02:01 PM   #3 (permalink)
the car starts it only moves on idle and it does jump when u change it to R and D
Old 06-01-2009, 07:25 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
How many miles and do you have any access to a code reader? Is this the first time it happened? Anything happen to the car or any work done to it? I hope it is not a bad ECU.
mikered30 is online now   Reply With Quote
Old 06-01-2009, 07:37 PM   #5 (permalink)
View 05DCLB's Photo Gallery
Probably is the ECU, Delco made and alot of problems. I think that has a 8yr and 96,000 mi warr. Get us a code if poss.
05DCLB is offline   Reply With Quote
Old 06-01-2009, 08:11 PM   #6 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
Aren't some of the 05s cable driven? Could the linkage be broken?
2010 Corolla S, stock(for now )
Gone
-08 Corolla S 5 Speed- A silverish color
Intake, Lights, STB - Ported & ploished - 35+Mpg
Rdkill is offline   Reply With Quote
Old 06-01-2009, 08:24 PM   #7 (permalink)
'11 Camry
Yeah, Acosta, does your throttle body have a cable on it, or is there no cable? Try this:
With the engine off, but the key on, open the hood in a closed area (like a garage) and slowly press the throttle and let go. You should be hearing the throttle butterfly open and close (if it's an electronic throttle). You can hear the little motor opening and closing the throttle blade. If you're not hearing that, there may be a malfunction with the throttle body, the wiring, or with the ECU.
