Looking to get an XRS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2009, 10:21 PM   #1 (permalink)
Mine is better than yours
iTrader Score: 6 reviews
View Marc M's Photo Gallery
I'm looking to get a 9th Gen XRS to replace my 2000 echo with 243,000 miles on it.
Is there anything I should look out for on these cars?
Are there different packages available on the XRS?
Is there a more desireable model than others?
Marc M
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5 / TRD Off Road
'05 Corolla XRS 6-Spd
'00 Echo 5-Spd
'90 4Runner SR5 5-Spd - '86 Shortbed 4X4 5-Spd,SAS'd ASAP - '82 Supra 5-Spd
Take your automatic and "Stick" it........
Marc M is offline   Reply With Quote
Old 06-05-2009, 11:57 PM   #2 (permalink)
Automatic Refusal
Exage's Avatar
View Exage's Photo Gallery
Hey Marc. The 9th gen XRS was only made for 2005, 2006 (most were 2005's). Just like any car, maintence records, accidents ect...
Some stuff to look out for:
Curbing: Check the wheels and side skirts for signs of curbing (rubbing on the curb) my XRS has noticable scratches on the passenger rear side skirt towards the rear tire. The rims have hit the curb a couple times as well and have scratches and dents. This was before I bought the car and I tend to stay a good 8-12 inches off the curb.
Serpentine belt: A squeeking noise coming from around the engine. Curable (tensioner adjustment usually), but annoying. Tell the dealer to fix it if you hear it when you start the 2ZZ-GE.
Interior Trim: The rubber around the rear drivers side door on my car seems to be too small. Not the rubber door seal, just the cosmetic wrap around stuff.
Engine 2ZZ-GE: Give it a good rev when on a test drive. Get it above lift; 6700rpm. This is really just for some fun, but the 2ZZ-GE engine is much more responsive over the normal eco 3000rpm shift point.
Gearbox C60: Test the gears, make sure they're good. My car crunches 3rd a little bit until it's warmed up (MT-90 is still working it's magic on it though!!!). You already have a 6-speed so getting it into 1st shouldn't be a problem (it was for me hahaha). The C60 is a close ratio gearbox so expect to shift it alot in the city, during eco driving.
If you need some pics of some of the cosmetic problem areas I can take some.
Packages: I don't know them for the US cars, sorry.
Newer is always better, but you can't go wrong with a low mile 2005.
The XRS is a fantastic car, and if you decide to pull the trigger, you'll have alot of fun.
2005 Toyota Corolla XRS (Phantom Gray Pearl)
2ZZ-GE: AMSOIL 5W-30 100% Synthetic, Toyota OEM Oil Filter
C60: Redline MT-90 GL-4
TRD Brake pads.
Exage is offline   Reply With Quote
Old 06-07-2009, 08:03 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1346597
I was under the impression that the XRS came from the factory fully-loaded with the exception of dealer installed accessories .
Old 06-07-2009, 09:01 PM   #4 (permalink)
Automatic Refusal
Exage's Avatar
Phat, I know that the Canadian XRS's are fully loaded. But it looks like in the US you had to order some options: Moonroof, 6-disc CD, Power windows, Power door locks, maybe some more?
TRD Brake pads.
Old 06-08-2009, 08:06 AM   #5 (permalink)
'11 Camry
View JasonA's Photo Gallery
I'm pretty sure that even in the US, there were no "trim" packages on the XRS. There were some stand-alone options (like what's listed above). But I didn't know that you could get a manual window, manual lock XRS. I thought they were pretty well loaded also.
JasonA is offline   Reply With Quote
Old 06-08-2009, 08:03 PM   #6 (permalink)
View omairtheman1's Photo Gallery
only options available are
moonroof
curtain airbags
6 cd
the rest is all the same as a regular S fully loaded... foglights and all
make sure u hit lift...
rape it
i have alot of toyotas... i love them...
basically....
omairtheman1 is offline   Reply With Quote
Old 06-09-2009, 12:57 AM   #7 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Exactly.
Look for:
- Clutch problems
- Transmission grinds
- Abnormal engine sounds (rattles etc.)
- A very rigid and tight steering ratio with wheels. If the steering shakes at highway speeds or feels very numb and lack of feel then the calibration is all messed up.
- Firm suspension that is very responsive in the corner (if it rolls too much in the corners then the shocks and springs are shot).
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 06-09-2009, 09:27 AM   #8 (permalink)
The one I'm looking at has the following added options:
PWR PKG[PO]
  • Keyless Entry
  • Power Door Locks
  • Power Windows
PWR SUNROOF[SR]
  • Power Tilt/Sliding Sunroof
  • Sun/Moon Roof
V.I.P. RS3200 PLUS SECURITY SYSTEM[V5]
It also has a new clutch.
Marc M
'00 Echo 5-Spd
