Noise from front brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2009, 07:39 PM   #1 (permalink)
View atifkm's Photo Gallery
Just installed brake shoes and rotors about 2 months before. Now front brakes are making squeaking noise when i brake. It was fine for about 2000 kms. Can you suggest some tips how to get rid of this noise.
atifkm is offline   Reply With Quote
Old 06-11-2009, 06:03 AM   #2 (permalink)
View dorman68's Photo Gallery
I have the same issue, I blame it on the cheapie brake pads. I suggest to add an anti squeal compound or a high quality ceramic brake pad. The ceramic pads have worked for me in the past on other vehicles I have owned.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 06-11-2009, 09:01 PM   #3 (permalink)
View masstoyota's Photo Gallery
There is a TSB out their for this issue.. you just need to apply some special grease..
masstoyota is offline   Reply With Quote
Old 06-12-2009, 12:11 PM   #4 (permalink)
Can you refer which grease is that and it's availablity.
Old 06-13-2009, 03:14 PM   #5 (permalink)
View tarbasd's Photo Gallery
Advance Auto Parts sells it at around cashier, if my memory is correct. Most likely other auto stores, too.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
Old 06-14-2009, 04:53 PM   #6 (permalink)
thanks, i just bought a bottle of disk brake quiet and applied on disk pads. hope it will work.
Old 06-15-2009, 07:44 AM   #7 (permalink)
If that's a can of spray, it is not what I referred to. It may work, but if it doesn't, you can buy the grease, take out the brake pads, and aplly the grease on the back of the pad, between the pad ans the metal bracket. This grease is sold in little packages for about $1.
Old 06-15-2009, 06:32 PM   #8 (permalink)
i checked that blue liquid becomes a little oily sort after a day use, and i'm not feeling any loss in braking, also upto now there is no noise while applying brakes.
