Maint required - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2009, 08:09 PM   #1 (permalink)
View rossn2's Photo Gallery
Maint required
Have an 07 Corolla with 21000 miles on it. Bought it with 16k miles on it. Right after starting the Main Reqd light flashed for about 5 seconds.
There's an oil change sticker from previous owner stating next oil change is 21100 miles. Well, I changed the oil and filter myself at 19700 miles.
How do you reset the light?
thanks
rossn2 is offline   Reply With Quote
Old 06-10-2009, 08:22 PM   #2 (permalink)
Sorry, did a search here. Had to look in Owners Manual and found out how to correct it under Indicators and Warnings section...geez...
Old 06-10-2009, 08:28 PM   #3 (permalink)
Dave's
Gameroom cash: $123350
View Dave's's Photo Gallery
Just so you don't hear it from others- 1st do a search. Think most work the same way. Try setting the mileage indicator to odometer. Then start with the key in off/locked and hold odometer button in while turning key to 'on' not start. Think you get 5 dashes (-----) which count down to none. When it goes to zero the light should be reset. Turn key to 'off'. Start car and light should not flash. (If it does, I screwed up the procedure, should be in your owner's manual). Good luck!
Dave's is offline   Reply With Quote
Old 06-12-2009, 12:34 AM   #4 (permalink)
View ladyofluck's Photo Gallery
I read from a site that ....
1.Key to "On". set to "Odometer"(not trip)
2.Key back to "Off".
3. Press and Hold Button on Dash, then Key to "On".
number reads 0000000. turn on the engine and light is now off...
is that the right procedure?
and is this maint required light thing just for your convienience? I just got this light too today; blinking 5~6 times when i turn on the engine. I thought I had to take the car to change engine oil in TOYOTA only!!! and Toyota has there special computer to reset the thing...
So I guess this thing keeps track of distance to tell you when to change? cause I was gonna use Trip meter B to keep track of my engine oil dues....
ladyofluck is offline   Reply With Quote
Old 06-12-2009, 01:22 AM   #5 (permalink)
Dave's
On mine it starts blinking at 4.5K miles since last reset. Goes steady at 5K. Just a reminder to change the oil.
Old 06-12-2009, 02:13 AM   #6 (permalink)
that seems quite long. isn't it supposed to be every around 3100miles? (around 5000 kilometers).
Old 06-12-2009, 08:10 AM   #7 (permalink)
Don't believe so...Oil change every 5000 miles here...
Old 06-12-2009, 09:20 AM   #8 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
Canada
in Canada here, dealer require oil change every 8000km on reg oil
2011 RAV4 I4 LTD with leather package. Used have 9th Gen Corolla with 2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 06-13-2009, 03:17 PM   #9 (permalink)
View tarbasd's Photo Gallery
Man, are you guys aware that certain booklets come with car? Users Manual tells you how to reset the light. Scheduled Maintenance Guide tells you when to change oil.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
Old 06-13-2009, 08:55 PM   #10 (permalink)
Dave's
Bought my last car at a year old. Didn't come with either manual. So I can understand someone not knowing. Plus the stealerships seem to really push 3K mile oil changes vs what the book says. But yes, it does seem easier to ask then to research sometimes.
Old 06-14-2009, 10:24 AM   #11 (permalink)
Just another word: you can (and should) buy a manual, if your car doesn't come with one. The dealer sells it. Ebay is cheaper. Toyota will send you a Scheduled Maintenance Guide and a Warranty Guide for free, if you call them.
