would a leak in the thermostat housing cause a low idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2009, 04:08 PM   #1 (permalink)
View jonjoe's Photo Gallery
European Union would a leak in the thermostat housing cause a low idle
would a leak in the thermostat housing cause a low idle seen some coolant at the side of the of the thermostat housing today it looks like a seal leak at the housing..having low idle problems for a while now
jonjoe is offline   Reply With Quote
Old 06-20-2009, 04:10 AM   #2 (permalink)
anybody???
Old 06-25-2009, 02:59 PM   #3 (permalink)
The Pwnstar
shadowtag88's Avatar
View shadowtag88's Photo Gallery
eh. i dont think it would cause low idle.. i guess it depends on how much is leaking...
how much fluid is needed to keep the system topped off?
the idle is controlled by the info the coolant temp sensor gives to the computer. if the coolant is warm enough the idle drops, if the coolant is cold, the idle is a little higher.. hence the higher idle for longer in the winter...
but if theres a bad leak... that might be able to throw of the sensor.... i dont know how but i would guess its not unreasonable that something tat little could do that.
just my thought...
shadowtag88 is offline   Reply With Quote
