Battery Voltage Question??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2009, 10:27 PM   #1 (permalink)
Canibe's Avatar
View Canibe's Photo Gallery
Canada Battery Voltage Question???
I need to know a few things about my car and battery voltage.
I know the battery is 12v but it is always above that.
If someone has done some test or can.
What is the peak voltage right off the battery running.
What is the lowest voltage running?
Also does the fuse box regulate the voltage by restricting 12v to needing devices.
What I am doing here is trying to make halos to go in my headlights. Need some info so i know what resistor to use with the leds.
Canibe is offline   Reply With Quote
Old 06-29-2009, 11:43 PM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
Car electronics, are actually made for, I believe 13.8 volts.
Yes it is a 12volt battery, but when it is being charged (aka when the car is running) it's voltage is actually in the mid 14's. The 13.8 figure accounts for voltage drops as the current goes through the car's electrical system.
Voltage should be in the 14's when running. Anything less than that, unless there is a HUGE load on the battery for some reason, is actually bad.
All the fuse box does is split power to the various circuits (save for some newer cars that have 42volt electronics throughout, but we won't get into that as it does not apply here).
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
