Fuse for radio + e mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2009, 09:27 PM   #1 (permalink)
View gm9492's Photo Gallery
Hi
My two year old managed to place a coin in the cig lighter cache and has shorted some fuse(s) on the 07 corolla. The radio, mirror adjust and cig lighter are all out. Does anyone know if this is a common fuse, and its abbrev. and amp rating; on the inside of the fuse cover?
Oh the joys of parenthood!
Much appreciated.
gmc
gm9492 is offline   Reply With Quote
Old 07-04-2009, 12:46 PM   #2 (permalink)
View toyota_b's Photo Gallery
Yeah bro i hear you there i am sporting the luxery model child seat with the big bird horn adapter...lol
You have two fuse panels on your car one is located right next to the fire wall on the drivers side of your vehicle and should have the fuse for rad... or radio and if you replace it everything should be back in working order other than having to reprogram the time and radio stations your enjoy.
you have a second fuse panel underneath the steering column of your car as well its usually way underneath and requires a bit of neck bending.
toyota_b is offline   Reply With Quote
Old 07-04-2009, 09:56 PM   #3 (permalink)
Thanks for that, although I found that because I am in Australia the fuse box inside the car was set behind the glove compart. which was where the "cig" fuse was located that fixed the issue.
Interestingly there was no "rad" fuse in either fuse box.
Thanks for your help on this one.
