brake vibration? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2009, 11:28 AM   #1 (permalink)
View f22b-dohc's Photo Gallery
brake vibration?
sup guys
i changed pads and rotors on my gf's 04.
when i brake hard, it shudders. i can feel it on the brake pedal.
any idea?
i've taken the abs fuses to see if it was the abs kicking in.
its still there..
arghhhhh
f22b-dohc is offline   Reply With Quote
Old 07-06-2009, 01:42 PM   #2 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Sounds like brake fade or warped rotors.
You said you got the brakes and rotors replaced?? You should take it back to the shop and ask them to test drive and see the issue.
Do you have your alignment and wheel balancing done??
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 07-06-2009, 02:24 PM   #3 (permalink)
doh, forgot to mention i did the pad and rotor change.
balancing s/b next
Old 07-06-2009, 08:39 PM   #4 (permalink)
'11 Camry
View JasonA's Photo Gallery
The rotors are new? You may need to take them back off and have a shop turn them...or at least check to see if there's thickness variation on the rotor (which could cause that pulsation feeling). Alignment and wheel balance should not contribute, but anything is possible. I'd most definitely start with the rotors before spending money elsewhere.
JasonA is offline   Reply With Quote
Old 07-06-2009, 09:05 PM   #5 (permalink)
View Axxis8203's Photo Gallery
sumthin's up with those rotors. you need to check the runout on them. you sure they're new?
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 07-08-2009, 01:14 PM   #6 (permalink)
new and out of the box.
Old 07-09-2009, 06:44 AM   #7 (permalink)
'11 Camry
I'd have the rotors turned. Brake shudder is normally not attributed to anything but thickness variation of the rotors (commonly mistakenly called "warped rotors").
Old 07-09-2009, 07:41 PM   #8 (permalink)
JimT
View JimT's Photo Gallery
Canada
Any chance you got grease or brake fluid on the pads?
JimT is offline   Reply With Quote
