Help narrow down the problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2009, 06:14 PM   #1 (permalink)
View mrsep48's Photo Gallery
USA Help narrow down the problem
I have a start up squeaky sound from the engine area of my 2004 Corolla with 56k. Could it be a belt, a pulley, water pump, or what? After about 5 mins from cold to warm it goes away and doesn't return till the AM start up the next day. Any suggestions?
mrsep48 is offline   Reply With Quote
Old 07-20-2009, 06:28 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Belt
mikered30 is online now   Reply With Quote
Old 07-20-2009, 06:43 PM   #3 (permalink)
Originally Posted by mikered30 View Post
Belt
Estimate part and labor, ball park?
Old 07-20-2009, 07:10 PM   #4 (permalink)
mikered30's Avatar
Belt is $30 and at the dealer 0.5 hours of labor at the dealer. It actually takes 1 min to take off the belt and 3 min to put it on. Also when they are replacing the belt have them check the tensioner too. But if the noise goes away, then it is likely the belt.
Old 07-21-2009, 06:32 AM   #5 (permalink)
View dorman68's Photo Gallery
Could be a belt or a weak tensioner. If the belt is old, I would try that first and then replace the tensioner if the noise is still there.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 07-21-2009, 11:27 AM   #6 (permalink)
Sensible's Avatar
View Sensible's Photo Gallery
There is a TSB for the Belt Tensioner Assembly. I just had mine replaced under warranty and the squeaking sound has dissappeared. I googled the TSB for my car , 2005 Corolla LE.
Sensible is offline   Reply With Quote
Old 07-21-2009, 07:31 PM   #7 (permalink)
Thanks for the tip
Old 07-25-2009, 12:59 PM   #8 (permalink)
View impulseRED's Photo Gallery
yeah my belt does the same thing, but i just ignore it , been doing so for 30k miles... i check about every 2 for wear and tear, there isnt any wear n tear.
so is this a common tensioner problem?
impulseRED is offline   Reply With Quote
Old 07-25-2009, 01:12 PM   #9 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
very common issue.
less common, but should check for is if the water pump is leaking.
fluid from the pump will spill onto the belt thereby causing the squeak sound that goes away when warm .
XR2003 is offline   Reply With Quote
Old 07-25-2009, 01:54 PM   #10 (permalink)
yeah i suspected so, its kinda nice personnaly. waking up to squealing in the garage makes cofee seem usless compared to that wreched SQUEAL.... lol
