lighter pulleys = MPG????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2009, 01:04 PM   #1 (permalink)
View impulseRED's Photo Gallery
i was thinking of adding some lightwieght pullyes to get some better gas mileage.....
would this work? would it also add some horsepower?
do lightwieght pullys have good integrity? or do they have overheating problems?
hot pullys + hot belt + high revs = bad lol.....
impulseRED is offline   Reply With Quote
Old 07-25-2009, 08:01 PM   #2 (permalink)
Gameroom cash: $181076
View thebrokeenthusiast's Photo Gallery
In theory, lighter pulleys would be good for efficiency, since it reduces parasitic drag on the engine, and for the same reason improves HP. IIRC, Unorthodox Racing makes a set and they claim a WHP gain of 7-11 HP. All motor honda boys have been using UR's pulleys for years without issue AFAIK.
- The Broke Enthusiast
thebrokeenthusiast is online now   Reply With Quote
Old 07-25-2009, 08:58 PM   #3 (permalink)
yeah i know about the hp CLAIMS..... i just want gas millage lol.....and less drag mean less wear and tear
ty
Old 07-26-2009, 03:39 PM   #4 (permalink)
Since the engine will have to work that much less, I assume you would indeed save gas. Kind of a moot point to spend $200 on pulleys to save a dollar a month at the pump...
Old 07-27-2009, 09:02 AM   #5 (permalink)
'11 Camry
View JasonA's Photo Gallery
Well, it would obviously depend on how much gas mileage you save.
Say you get a 1 MPG savings. Also say you drive 20,000 miles a year and average 32 MPG with the old pulleys, and 33 MPG with the new pulleys.
At $2.50/gallon, your old fuel costs/year are $1,562.50. At the same $2.50/gallon, your new fuel costs/year with the new pulleys are $1,515.15. That's a difference of almost $50/year. After four years, they'd have paid for themselves.
Now, I don't have a clue how much gas mileage you might save. But if lighter pulleys have demonstrated a 10% gain in power, at the wheels, you might also reckon that there'd be a measurable gain in economy also, at least enough to offset the cost in a few years.
JasonA is offline   Reply With Quote
Old 07-29-2009, 09:54 PM   #6 (permalink)
caddymac's Avatar
View caddymac's Photo Gallery
If lighter pulleys were all that it takes for increase in gas mileage, why wouldn't Toyota do it from the factory?
caddymac is offline   Reply With Quote
Old 07-30-2009, 06:40 AM   #7 (permalink)
'11 Camry
It's not only lighter but also different diameters (as in larger). If you spin the accessories slower, it takes less power. But the downside is reduced performance from those accessories. We did that on a '92 Mustang we had and the battery would die every now and then, because the alternator wasn't charging it enough (due to the slower speed it was turning). A/C performance might also be effected.
There is no free lunch. There will be a compromise.
Old 07-30-2009, 05:58 PM   #8 (permalink)
That only apples if you don't overdrive the alternator pulley. Also, Aluminium pulleys are much softer than the steel ones used in the factory. Building an engine is all a compromise for reliability. They could have used a different cam spec, and gained more HP and mileage, but the wear and tear on the engine would be too much, and reduce the life of the engine. Even above efficiency, reliability is the primary goal of any OEM engine.
Old 08-02-2009, 09:03 PM   #9 (permalink)
yeah i figured that, ...... would lightwieght stainless steel be a better comprimise?
Old 08-02-2009, 09:07 PM   #10 (permalink)
on full afterburner
Gameroom cash: $1345597
Stainless steel isn't light lol. Not by any means.
If you want pulleys, get them.
Old 08-02-2009, 09:07 PM   #11 (permalink)
well the pulleys that you CAN buy are the same diameter as the OEM just a few pounds lighter....... which is alot considering thier size
i know the chance of comprimise using a lighter wheel, i got a friend who fabricates carbon fiber, i was thinking that could be an option if it could work, any advice?
Old 08-02-2009, 09:11 PM   #12 (permalink)
on full afterburner
I've seen carbon fiber pulleys used in applications of road racing bicycles, but never in an automotive application.
I doubt it would work efficiently or safely enough to warrant the cost.
Old 08-02-2009, 09:25 PM   #13 (permalink)
hmm really? what are the concerns of carbon fiber pullys, ive never read anything about them b4
Old 08-03-2009, 12:54 AM   #14 (permalink)
There is a smart option, but you'd have to convince the right person to make your pulleys. MRZ Performance out of Quebec makes a pulley that is almost all aluminium, but uses steel on parts of the pulley that usually wear out on all aluminium ones. If you garner enough interest in a product, they'll produce and sell it. I've bought their stuff before, and it's top notch.
The problems I could see with CF are slippage and premature wear. It needs to be resin coated to hold together well, and resin isn't exactly a high friction surface. This would potentially cause slippage. The problem with premature wear would be the risk of fibers separating once that resin is worn. It could potentially be a great short term idea, but you'd be replacing them often. I wouldn't even try it on a good production engine with out lots of wear testing (at least a good month of straight testing on a high rpm electric motor in a separated closed space, constantly running). It would also have to be 100% flawless in build quality to work properly.
Old 08-03-2009, 12:24 PM   #15 (permalink)
well i was going to get the pullys made out of carbon fiber but have a carbon sainless steel ring fitted on the outside of it for grip and less wear
would this be a better comprimise?
it would be cheaper for me to get my friend to make it than to by if from a preformance company, plus it would be nice to test something like that out
my friend said they would be relativly the same wieght as aluminum plulleys but i wouldnt have to worry about the softness of aluminum
