03 corolla dynamat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2009, 05:44 PM   #1 (permalink)
View yosemitesam's Photo Gallery
03 corolla dynamat
So after getting sick of all the rattling i decided to get the Dynamat Extreme on amazon for $140 (cheaper than crutchfield - $250). It the one with 9 sheets of 18"x32".
My question is how much do i need for the corolla and in what places do i put is as in do i just do the truck floor or also the top and the trunk lid. I also have the aftermarket speaker with the brackets that rattle.
Please help. Thank you in advance for help
yosemitesam is offline   Reply With Quote
Old 07-29-2009, 08:39 PM   #2 (permalink)
10' Corolla S
View Rdkill's Photo Gallery
You can stop most of the speaker rattle with some of those molded foam inserts that go behind the speaker and mount between it and the bracket.
Do you have subs? if not theres no need to soundproof the trunk.
2010 Corolla S, stock(for now )
Gone
-08 Corolla S 5 Speed- A silverish color
Intake, Lights, STB - Ported & ploished - 35+Mpg
Rdkill is offline   Reply With Quote
Old 08-03-2009, 08:19 PM   #3 (permalink)
View jdmay's Photo Gallery
I have 2 10" subs in my trunk along with aftermarket 6x9s and have needed any sound proofing yet.
jdmay is offline   Reply With Quote
Old 08-05-2009, 01:21 PM   #4 (permalink)
I have 2 10" subs as well and there is a lot of squeeking in the back. Well anyways I got the dynamat and also a capacitor
It is a Tsunami LiteWave PP1002TM-CAP. and heres my second question ( sorry didnt want to make a new post)
how do i install it. it has six places for wires ( 3 on each side) does any one know the wiring on this
please help
thanks
Old 08-05-2009, 05:24 PM   #5 (permalink)
I have a capacitor set up in mine. All I had to do was run the power cable from the battery/in-line fuse to the positive terminal on the cap. Then run another power cable from the cap to the amp. Ground the cap from the negative terminal. Then ground the amp. Just make sure to disconnect the battery and take the in-line fuse before you install the cap. Here's a pic of an older setup that I had.
Old 08-14-2009, 04:30 PM   #6 (permalink)
View the4starish's Photo Gallery
Are you talking about Foam Baffles like these:
http://www.crutchfield.com/S-IHdfgYJ...r-Baffles.html
the4starish is offline   Reply With Quote
