DIY: Replacing Engine Cover Plastic Retainers
I lost one of those plastic retainers that retain the rear side of the engine cover. So I replaced those silly things with the same small stud that's in the front left corner.
The part number for the "BOLT, STUD" is 92122-80612 (list $1.08 each) and the part number for the "NUT, CAP" is 90176-06028 (list $1.57 each). You'll need two of each.
It sounds expensive for what you get, but for 5 bucks, you can get rid of those silly plastic retainers forever. The stud is just long enough to poke up through the engine cover so that you can use the exact same 10mm nut that holds down the front side of the cover.
