Dimmer control stopped working
I have a 2005 Corolla and had a set of components installed yesterday, along with an amp in the trunk. The dimmer control (to dim the gauges, nighttime lights, etc) no longer does that, however it does still control the dome light. The lights on the center stack that normally come on with the headlights don't work either.
Normally, when the headlights go from DRL to full low beam I hear a click in the dash but there is nothing now, just the headlight icon on the dash. The DRL's and auto headlights do still work perfectly, as does everything else in the car. So far as I can tell, none of the fuses are blown.
While I would normally march back and tell them to fix it (it was a local shop) I'm afraid they would just make it worse.
Any ideas on what to check? Is there a relay somewhere in the dash that they might have knocked loose? Thanks for any ideas.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
