idle speed control valve assy on a 04 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2009, 12:59 AM   #1 (permalink)
View 04rollaftw's Photo Gallery
USA idle speed control valve assy on a 04
Hi guys
I was trying to clean the idle speed control valve assy on my 04 rolla hoping for a smoother idle. Took the whole thlottle body assy off. Was relatively easy using the repair manual as a guide. However I was unable to unscrew the bolts on the idle speed control valve assy. they were so tight that I coulnt do anything without breaking things. Ended up striping 2 of them(just the head so the screw driver doesnt work anymore). The third one came off right out somehow. I had to go out so didnt clean the valve but the thlottle body and put everything back. No noticiable change.
What should I do with the 2 stipped bolt? They wont come out.
Thanks in advance
04rollaftw is offline   Reply With Quote
Old 08-30-2009, 11:08 PM   #2 (permalink)
View joshzisky's Photo Gallery
Canada
put it back in! vice grips? slot the head of the screw with a cutting disc and use a flate screw driver? take the head of the bolt completely off, the remove with vice grips? you can figure it out, just pretend you have to get it done or you'll lose you're car... something should come to you.
you may end up having to drill and tap the holes if extraction is futile.
joshzisky is offline   Reply With Quote
