Confused with Wheel offset - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2009, 11:44 AM   #1 (permalink)
05 Rolla
View RawDarkness's Photo Gallery
I am looking to buy new rims finally and I am lost with the whole wheel offset. I do not understand what it means and I have searched to try and get an understanding but I am still confused. I believe the stock wheel width of an 05 corolla is 6.5" so how big should I go and what offset range should I stay with?
RawDarkness is offline   Reply With Quote
Old 09-01-2009, 11:59 AM   #2 (permalink)
on full afterburner
Gameroom cash: $1345597
http://www.raceandroad.com/offset.asp
http://en.wikipedia.org/wiki/Offset_(wheel)
Old 09-01-2009, 12:14 PM   #3 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
I'm pretty sure that our 'rollas run a 6 inch OEM wheel. Offset 42mm???
Someone will chime back in, I am sure.
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 09-01-2009, 01:48 PM   #4 (permalink)
'11 Camry
View JasonA's Photo Gallery
Our wheels are 6" wide. I thought the offset was an even 40mm on the Corolla.
Here's a good page, with a diagram:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
JasonA is offline   Reply With Quote
Old 09-03-2009, 11:01 PM   #5 (permalink)
05 Rolla
Thanks for the replies and being nice about it too. So i guess finding a wheel with an offset of 40 to 45 is probably the best bet then
Old 09-04-2009, 08:34 AM   #6 (permalink)
View atifkm's Photo Gallery
it is +45mm, See link below:
http://farm3.static.flickr.com/2592/...fbfb9057_b.jpg
atifkm is offline   Reply With Quote
Old 09-04-2009, 09:16 AM   #7 (permalink)
'11 Camry
Thanks for the correction!
Old 09-06-2009, 06:28 PM   #8 (permalink)
05 Rolla
Thank you
Old 09-08-2009, 01:39 AM   #9 (permalink)
View aznboiquyen's Photo Gallery
OffSet
I was quite confused with the offset myself, but let me do my best to explain. Though i do recommend that you find the offset "number" online...there are times that you may have to measure it.
My definition: The offset is the distance (mm) from where the mounting surface of the hub caps to the center line of the wheel. I don't know how else to explain it sorry. I hope this thelps. But the Offset is generally measured in millimeters.
But in all honesty...For me, The offset does not really matter unless you are going to a drag strip and racing, OR if you are upgrading your wheels (which is probably what you're doing) But our Corolla's (03-08) can go up to 17'' wheels without any issues. At 18'' i would be questioning the offset.
aznboiquyen is offline   Reply With Quote
Old 09-08-2009, 01:55 AM   #10 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
Offset has basically nothing to do with the diameter of the wheels, and everything to do with the width of the wheels.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is online now   Reply With Quote
Old 09-08-2009, 09:39 AM   #11 (permalink)
'11 Camry
Yes and no. When the diameter gets large enough, you need to pay close attention to the offset to make sure you don't put a tire into the lip of the wheel well.
Old 09-08-2009, 02:17 PM   #12 (permalink)
Jeff Lange's Avatar
True, however that will also be an issue of how wide the wheel is, because even with a smaller diameter and a wider wheel then the tire will be pushed into the lip of the wheel well.
In any case, it's all important, that's what you need to know, haha.
Jeff
Old 09-08-2009, 05:31 PM   #13 (permalink)
here is a link to explain offset:
http://minitruckin.automotive.com/69...ing/index.html
Old 09-09-2009, 07:28 PM   #14 (permalink)
05 Rolla
Great replies to the thread. It has really helped me understand much clearer. I guess the last thing I would like to know is how thick/wide can the wheels be before my wheels hit the car body when turning?
