Starter Location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2009, 07:13 PM   #1 (permalink)
View birdii's Photo Gallery
Starter Location
Hi, I have a 2004 corolla and the starter is on its way out. I'm looking for some help asap. Where is the starter located and what parts do I have to remove to get to it?
thank you
birdii is offline   Reply With Quote
Old 09-07-2009, 12:29 PM   #2 (permalink)
View rsirois's Photo Gallery
The starter is located front side of engine on the transmission side. Just under intakes.
Removal:
(a1) Disconnect battery.
(a) Disconnect the starter connector.
(b) Open the terminal cover.
(c) Remove the nut, then disconnect the starter wire.
(d) Remove the 2 bolts, then remove the starter
rsirois is offline   Reply With Quote
Old 09-07-2009, 01:58 PM   #3 (permalink)
Thank you for the reply. I removed those 2 bolts and the starter doesn't even want to move. I put some muscle into it and its not moving
