Engine knocking... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2009, 12:07 AM   #1 (permalink)
View jtmartin's Photo Gallery
Engine knocking...
I'm new to Toyota's, Mainly have knowledge in hondas. Theres so many different things about my Corolla that I cant really decide where to start looking for this problem...
theres a link to the vid... I have a gut feeling its a rod/main bearing but I have hopes for it being something else. I'm pulling the oil pan off sometime this week to take a look, In the meantime I am NOT driving it.
Please let me know any suggestions as of what else it could be. I'm really not looking to rebuild this thing
Milage 133980
2003 Toyota Corolla CE
Engine 1ZZ-FE?? Correct me if I'm wrong...
Thanks in advance.
jtmartin is offline   Reply With Quote
Old 09-14-2009, 12:18 AM   #2 (permalink)
View tigerclaws1318's Photo Gallery
Thats some pretty bad sound coming from the engine. Almost sounds diesel powered lol. When you hear knocking sounds first thing you do is to check the oil level. A stethoscope comes in handy to locate where the main sound is coming from. Other than that good luck finding the source to that sound.
tigerclaws1318 is offline   Reply With Quote
Old 09-14-2009, 12:14 PM   #3 (permalink)
I've heard some people say that a water pump can make this noise too... or a belt tensioner?
Is there any hope for it NOT being a spun bearing?
Old 09-14-2009, 05:11 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $467667
what oil and filter do you use?
mikered30 is online now   Reply With Quote
Old 09-14-2009, 06:50 PM   #5 (permalink)
I bought it and the woman had just done an oil change. The reciept was in the glove compartment.
Valvoline 10W30 with a valvoline filter maybe? Its almost due for an oil change. 500 Miles away. I'm going to drain the oil and drop the pan tomorrow and take a look around.
Anyone know the torque specs for the connecting rod caps on a 1ZZ-FE?
Old 09-14-2009, 07:19 PM   #6 (permalink)
mikered30's Avatar
18 ft pounds, I think.
http://www.users.on.net/%7Ebmrogers/2004.zip
There is the manual if you want to download it, it has everything you are looking for. Does this noise go away when the car warms up or is it constant?
Old 09-14-2009, 07:56 PM   #7 (permalink)
18ftlbs wow... thats nothing. Btw. Mine is a 2003. that manual is for a 2004 any differences?
No the noise is solid and consistant, cold or hot, any rpm. but it never seems to get louder. no matter what. its quite strange.
Old 09-14-2009, 08:01 PM   #8 (permalink)
mikered30's Avatar
Yeah, it will be fine. The 03-08 use the same engine, with very minor changes. I dont think there are any engine changes from 03 to 04. There were some tranny changes though.
I am pretty sure it is 18 ft pounds, double check to make sure.
Engine is specd for 5W-30 oil.
These engines are notorious for crappy belt tensioners and belts. Can you confirm the noise is not the tensioner? It would be something to eliminate.
Old 09-14-2009, 08:13 PM   #9 (permalink)
Cool.
Yea, I'll give that a second look. I'm giving the car a good going over.
Old 09-14-2009, 08:22 PM   #10 (permalink)
mikered30's Avatar
Not sure if you saw my last edit, but take a very close look at the tensioner. They suck so much Toyota put out a TSB on it. Dayco makes a nice replacement.
Old 09-14-2009, 08:42 PM   #11 (permalink)
'11 Camry
View JasonA's Photo Gallery
It may be a crank bearing. Sometimes the front crank bearing can get some play in it from being constantly loaded by the belt, and make that sound as it loads and unloads. Certainly try removing the belt all together and see if it makes the noise. If it does, you know it's not the belt or tensioner, and the crank bearings are likely okay as well.
I assume you're chasing the low "thumping" sound. That seems pretty slow to be related to anything on the crank. But it sounds like it's deep enough and low enough physically in the engine that it can't be anything else. Could be something odd like an oil pump.
JasonA is offline   Reply With Quote
Old 09-15-2009, 07:32 AM   #12 (permalink)
Well It sounds a bit crazy, But I may have found the source of this sound. Theres a spot on the serpentine belt that doesnt have any ribs on it, and as it passes over the alternator pulley it kinda tracks sideways at the exact time of the noise. Also the noise doesnt change/get louder under load.
I'm goign to pick up a new belt today and see how everything goes lol. I'll kick myself in the ass if it is a belt.
Old 09-15-2009, 07:53 AM   #13 (permalink)
View dorman68's Photo Gallery
Torque for connecting rod caps is 15ft lbs plus an additional 90 degree or quarter turn. I would check the oil pump pick up tube for any obstructions.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 82,000mi
2003 Echo - Auto Trans - 95,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
1993 Ford Ranger - 5speed - 2.3L
dorman68 is offline   Reply With Quote
Old 09-19-2009, 08:12 PM   #14 (permalink)
Funny story. The motor was off yesterday, and I happened to see a spot on the serpentine belt that didnt have any ribs... odd. So I started the car and watched the alternator pulley, and every time this spot on the belt went over that pulley, it would make that hollow knocking sound.
So I got a little worked up and concerned since this car is new to me, But I'm happy it was just the belt. I changed the belt (=no fun) by myself and the noise is gone. Thanks to all that posted and helped out.
Old 09-21-2009, 09:45 AM   #15 (permalink)
Awesome!! Good to hear a happy ending.
