I have done this before. You do not need to touch the hardware.
Rear Hub Replacement as per service manual
REMOVE REAR WHEEL
REMOVE REAR BRAKE DRUM SUB-ASSY
DISCONNECT SKID CONTROL SENSOR WIRE (W/ ABS) - If equipped
REMOVE REAR AXLE HUB & BEARING ASSY LH
Remove the 4 bolts and hub & bearing assy LH.
INSTALL REAR AXLE HUB & BEARING ASSY LH
Install the hub & bearing with the 4 bolts. Torque: 61 Nm (622 kgf-cm, 45 ft. lbs.)
CONNECT SKID CONTROL SENSOR WIRE (W/ ABS) -if equipped
INSTALL REAR BRAKE DRUM SUB-ASSY
INSTALL REAR WHEEL Torque: 103 Nm (1,050 kgf-cm, 76 ft. lbs.)
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 82,000mi
2003 Echo - Auto Trans - 95,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
1993 Ford Ranger - 5speed - 2.3L
