Steel Wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2009, 03:48 PM   #1 (permalink)
Toyota FAN
View derickveliz's Photo Gallery
Steel Wheels
Where could I buy a couple of steel wheels for my corolla?
Thank you,
Derick
derickveliz is offline   Reply With Quote
Old 10-07-2009, 04:36 PM   #2 (permalink)
Gameroom cash: $117630
View gideon1331's Photo Gallery
Your best bet would be to check with your local junkyards. They will usually have a couple from salvage cars that have not been damaged.
You can of course buy them from a dealer, but you will get charged an insane amount for them.
The only potential issue is if you have the tire pressure monitor system. I don't know what is involved with the sensors, where they are installed, if they can be transferred, etc. Hopefully you either don't have TPMS, or someone else can shed some light on the subject.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 10-07-2009, 04:49 PM   #3 (permalink)
Toyota FAN
Thank you, I'll check junkyards around the area (not many)
the good thing is that my corolla has no TPMS !
Derick.
Old 10-07-2009, 04:55 PM   #4 (permalink)
View hungt1999's Photo Gallery
Costco or Wal-Mart
it's around $40 to $50 per wheel depending on the size
hungt1999 is offline   Reply With Quote
Old 10-07-2009, 10:23 PM   #5 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
Originally Posted by hungt1999 View Post
Costco or Wal-Mart
I've seen them new at Discount Tire for that too... but I'd try the salvage yards first. TPMS really came on in 2008+ model years.
Did you hit a curb?
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 10-07-2009, 10:29 PM   #6 (permalink)
View ford_jj's Photo Gallery
does steel wheel better?
I think most of wheels are not the steel.
Thanks.
ford_jj is offline   Reply With Quote
Old 10-07-2009, 10:44 PM   #7 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
Canada
junk yard should be very last spot to look for rims, if you can effort don't get junk yard rims, didn't say they are not good, but you never knows, you dont know they from retired car or accident car, if they are from accident car, they might be damage, twisted, and the very bottom line, they don't take them back once out of the door you are on your own. and yes they are cheap but as for myself I don't gamble.
2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 10-07-2009, 10:45 PM   #8 (permalink)
Offcial TN Newbie
Slaander's Avatar
Thank you,
Derick
and make sure the middle hole is 60mm or larger, corolla using 60mm center hole. off set is 38-43 I believe. 5 x 100 pattern.
Springs
Old 10-08-2009, 06:37 AM   #9 (permalink)
View dorman68's Photo Gallery
I have found one on Ebay when I needed one.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 82,000mi
2003 Echo - Auto Trans - 95,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
1993 Ford Ranger - 5speed - 2.3L
dorman68 is offline   Reply With Quote
Old 10-08-2009, 08:31 AM   #10 (permalink)
View olbus's Photo Gallery
I've replaced two. One got bent and replaced with a junkyard one, $50. One to replace the donut with a real spare with a new generic wheel from Discount also about $50. Most tire shops sell these and they should be straight if new. The hubcap seems to fit fine so to me it's just easier to get the generic.
olbus is offline   Reply With Quote
Old 10-08-2009, 09:36 AM   #11 (permalink)
'11 Camry
View JasonA's Photo Gallery
I thought the Corolla had the "small" Toyota center bore, 51.3mm?
JasonA is offline   Reply With Quote
Old 10-08-2009, 09:37 AM   #12 (permalink)
'11 Camry
TPMS came on some 9th gens, but not all. I think it came on ABS cars, or was at least optional on ABS cars. At least on the 9th gen, it used no sensors in the wheels. It was simply a speed differential thing, measuring the speed of each wheel via the ABS reluctor rings. In essence, if one tire is low, its rolling radius will be smaller, and it'll rotate faster than the other three.
Old 10-08-2009, 10:04 AM   #13 (permalink)
Toyota FAN
Did you hit a curb?
No I did not hit a curb, just looking for winter tires with steelies.
Thanks to every body, looking forward to see all your suggestion.
Derick
Old 10-08-2009, 12:32 PM   #14 (permalink)
Offcial TN Newbie
Slaander's Avatar
Canada
yeah is 54.1 mm I keep thinking on the camry rims. as the link below for aftermarket rims size.
http://www.streetdreams.org/wheels-t...Toyota/Corolla
2008 Toyota
Corolla
Bolt Pattern: 5x100
Center Bore: 54.1
Hardware:12x1.50 Lug
Offset: 34-42mm
Springs
Old 10-08-2009, 12:33 PM   #15 (permalink)
View tigerclaws1318's Photo Gallery
I don't know how junkyards operate or how they move their cards around. But on tv I see that the cars are picked up on cranes and then dropped from a couple of feet from the air. If the car has no air in the tires then the wheels take the impact causing the wheel to be seriously damaged or bent.
Just my reason I would stay away from the junkyard for wheels.
tigerclaws1318 is offline   Reply With Quote
