.... 1st Punctuation.
Ok, formalities out, here's the layout. You dont need to clean the piston (its going to get dirty real fast anyways). The grease is used when the pads aren't spaced out by springs that keep the pad off the rotor (you should have it seeing its a 9th gen Corolla).
Here's the
important part:
only c-clamp on the piston and the caliper (metal part) itself, not the hose. Make sure you dont bend the brake line too much or you can possibly snap it and lead you to a boatload of trouble. When you put it back (tires and everything), make sure you pump the brakes to reset the pistons on the calipers so that you "wont have brake loss" before you drive it.
There should be pics on line if you look around. Hope this helps
