Originally Posted by jupiterhenry
Don't worry, it's not as bad as it sounds, I'm not rolling around endangering the public...but you make a good point.
No, I'm sure not, but the law knows no grey area. Most folks don't realize (I never did) that any good lawyer will make you weight your vehicle and trailer, and at that point, you're out on your own in terms of legal protection. It wouldn't be a fun process.
I'm gonna reorganize the inside of my trailer so the weight is balanced right every time, and as you point out, that shouldn't be enough to slam the rear end of the rolla.
Yeah, adjust the load so that the trailer is fairly balanced. You want a BIT of the weight just forward of the trailer's axle (just slightly front heavy) to add some stability to the whole thing (if it's rear heavy, it'll tend to yaw back and forth).
And do study your owner's manual carefully to see what you CAN tow. The towing limit is often quoted with no other passengers in the vehicle. If the tow limit is, say, 1000 pounds, you probably need to reduce that if you're carrying 3 other people. It's the GVWR, or Gross Vehicle Weight Rating, you're concerned about. That'll be printed on the tire pressure placard found in your driver side door jamb. On my Corolla, it's 3585 pounds. That means that the total weight of my vehicle, passengers, fuel, luggage, trailer, etc, cannot weigh more than 3585 pounds. I know the curb weight is around 2500. I weigh 230 myself. Add some fuel and a passenger, and it's an even 3000 pounds. That leaves only 585 pounds for my trailer. I couldn't even pull my jet ski with the Corolla...not even with NO passengers in it (not legally anyway).
Figure the curb weight of your car to be around 2500 pounds. Figure out how much you weigh, and how much your passengers weigh, and figure out how much "extra" you have available, after you compare that to your GVWR printed on your tire decal. Vehicles (and especially small ones) are generally designed to be "maxed out" when the maximum number of passengers are aboard, leaving little extra capacity for a trailer.
