Can I use a ECM off a 2005-2007 in my 2003 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2009, 02:40 PM   #1 (permalink)
rainking1978's Avatar
View rainking1978's Photo Gallery
Can I use a ECM off a 2005-2007 in my 2003? Are they all the same from 2003-2008? I need my ECM flashed but might be cheaper to get a new ECM if it will work. Thanks.
2009 Honda Civic Si
2005 Corolla CE
2006 ZX10R
rainking1978 is offline   Reply With Quote
Old 10-20-2009, 06:15 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
no, i don't think so. there were a few changes between the 2003/2004s and the 2005 and ups. im sure another member can elaborate on it for you.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 10-20-2009, 08:43 PM   #3 (permalink)
Automatic Refusal
Exage's Avatar
View Exage's Photo Gallery
I think the switch to a drive by wire ECM might cause problems... so I wouldn't bet they're compatible.
2005 Toyota Corolla XRS (Phantom Gray Pearl)
2ZZ-GE: AMSOIL 5W-30 100% Synthetic, Toyota OEM Oil Filter
C60: Redline MT-90 GL-4
TRD Brake pads.
Exage is offline   Reply With Quote
Old 10-21-2009, 05:22 AM   #4 (permalink)
View dorman68's Photo Gallery
They are not interchangeable. The 2007-05 model years use a transponder key, therfore the pcm will be looking for a matching chip key to allow the vehicle to start. I would stick with the reflashing.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 10-21-2009, 06:54 AM   #5 (permalink)
OK, thanks guys!
2009 Honda Civic Si
2005 Corolla CE
2006 ZX10R
Old 10-21-2009, 03:31 PM   #6 (permalink)
Gearhead
Gameroom cash: $196215
I didn't thing that the Toyota ECMs were completely flashable - or at least to the extent of other manufacturers. I know that you can burn-in a new configuration for certain parameters (emissions, shift logic, etc.) but must be done through a Toyota scan tool. I have not seen any aftermarket alternatives as of yet. Just curious, what are your plans for the OEM ECM?
Old 10-21-2009, 06:30 PM   #7 (permalink)
I need to get this done.
http://corollatoys.org/service/files/EG028-04.pdf
2009 Honda Civic Si
2005 Corolla CE
2006 ZX10R
