Wiper Replacement and Headlight Haze - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2009, 11:24 PM   #1 (permalink)
View triadguy's Photo Gallery
Any suggestions on a good quality windeshield wiper replacement for my '04 Corolla LE. I have seen these Goodyear wipers being sold in Costco recently and was thinking of picking up a pair.
Also, I've noticed the front headlights on my car have a lot of haze on them and it is affecting visibility while driving at night. What is usually done to correct this problem (is a complete replacement necessary?).
Thanks in advance.
triadguy is offline   Reply With Quote
Old 10-28-2009, 05:37 AM   #2 (permalink)
View rsirois's Photo Gallery
Meguiar's sells a headlight restoration kit. I've heard it works pretty well on hazy headlight lenses.
http://www.meguiarsdirect.com/detail/MEG+G1900
rsirois is offline   Reply With Quote
Old 10-28-2009, 05:42 AM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
OEM inserts work well for me. A very good cleaning, not just a wash, of the windshild often cures what people call bad wipers.
The Meguiar's PlastX plastic cleaner works very well to remove haze. Multiple applications by hand are necessary and then cover the lens with a good wax.
mikered30 is offline   Reply With Quote
Old 10-28-2009, 06:15 AM   #4 (permalink)
View empirefalls's Photo Gallery
Wipers? Valeo 600 series. About $16 for 2 at Amazon, Difficult to find at retail stores.
Anco 30 series are inexpensive but highly rated. Avoid expensive blades they are very overpriced.
Read more here:
http://pressroom.consumerreports.org...fade-fast.html
Hazy Headlights?
BE CAREFUL WHAT YOU USE. Avoid anything that sands.
Meguiar's usually are superior auto products however i have no feedback on their headlight restoration. I tried Meguiar's cheaper bottle of lens cleaner, did not seem to help
Read here for excellent information:
http://answers.yahoo.com/question/in...2080946AAtrq16
Walmart sells a silver packaged Headlight restoraton Crystal View about $19--, sometimes marked down to $16--
I have heard firsthand excellent remarks from mechanics who have used it.
See video here:
http://www.myheadlight.com/
I bought two pair of Silverstar headlights(Ultra for the high and regular Silverstars for the low beans) at Amazon for $20 for two, Usually $40-$50 at retailers. They improved my headlight visibility very much, although the bulbs have a one year life span. Need more advice on these bulbs let me know. There are some points to consider. One headlight bulb change on your Toyota Corrola may require the battery to be taken out and still tricky to install.
empirefalls is offline   Reply With Quote
Old 10-28-2009, 09:09 AM   #5 (permalink)
GO KING'S GO!
dktaco's Avatar
View dktaco's Photo Gallery
For wipers my 05 Taco and my wife's 03 Corolla have Rain X Latitude blades. They are over 1 yr. old and these things are amazing. Best deals are usually on e-bay for them. They sheet rain and do not skip or jump. As for headlight restoring forget doing it with hand. Use a dual action buffer like a Porter Cable get a medium cut pad and a medium polish like XMT (Pinnacle) or Poorboys...over the counter Meg's or Mothers will work too. You can buy a kit if you want to do it right, but I already have all my pro detail stuff and do them with a 6" pad. Here is more info http://www.autogeek.net/wolfgang-headlight-how-to.html And lastly if this doesn't help you must use 2000 grit wet/dry sand paper to get out all the oxidation and fading. I only recommend pro's do this or if you can thoroughly read directions and are attention to detail.
dktaco is offline   Reply With Quote
Old 10-28-2009, 09:58 AM   #6 (permalink)
'11 Camry
View JasonA's Photo Gallery
I used the 3M kit, and it came with 300 grit paper, 600 grit paper, 3000 grit paper, and a disc that you chuck into a drill. I did that on the headlights on my Dakota and got amazing results.
Before:
After:
Compare left and right:
JasonA is offline   Reply With Quote
Old 10-28-2009, 10:01 AM   #7 (permalink)
'11 Camry
For blades, the Michelin ones from Walmart have worked the best for me. 6 or 7 bucks each. Cheap, and last a long time. I've had lousy luck with the Rain X ones (they chattered right out of the package, and I got the same results on two different vehicles with two different pairs of them) and Bosch MicroEdge blades (they didn't last long at all). Fortunately, Walmart let me return the Rain X ones.
Old 10-28-2009, 10:13 AM   #8 (permalink)
GO KING'S GO!
dktaco's Avatar
Which Rain X? I am almost positive it wasn't the Latitude!
Old 10-28-2009, 11:26 AM   #9 (permalink)
Wow everyone!!! Thanks a lot for all the excellent info and recommendations!!! I'm pretty much mechanically challenged, LOL! I'm so glad I'll be able to clear up that headlight haze/fog myself and don't have to pay a whole lot to have someone else do it.
This forum rocks!
Old 10-29-2009, 12:09 PM   #10 (permalink)
on full afterburner
Gameroom cash: $1345597
Bosch Icons, get a set and get $15 back from them via a mail in rebate. Good until new years eve.
Solid wiper blades.
Old 10-29-2009, 08:17 PM   #11 (permalink)
'11 Camry
I don't know what they were called. The set I tried a few years ago had a conventional frame. The set I tried about 6 months ago was the new curvy frameless ones. Both chattered right out of the box.
Old 10-29-2009, 11:38 PM   #12 (permalink)
GO KING'S GO!
dktaco's Avatar
Well, without a name that doesn't do us any good.
Old 10-29-2009, 11:42 PM   #13 (permalink)
on full afterburner
Agreed. I recommended a set of Rain-X Latitudes to my friend for his Sienna, and they ended up working great. No streaking or chattering. But if you had a problem with those wipers, you could've returned them to the store where you bought them and got something else.
Old 10-30-2009, 05:23 PM   #14 (permalink)
'11 Camry
Well, according to RainX's website, the frameless ones are the Latitudes:
http://www.rainx.com/Products/Wiper_.../Latitude.aspx
So I bought one set and they chattered. Luck of the draw I guess. Got my money back, so no harm done.
Old 10-30-2009, 06:42 PM   #15 (permalink)
GO KING'S GO!
dktaco's Avatar
I can guarantee you gotten a bad apple!
