New belt tensioner - 16620-0W093 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2009, 04:11 PM   #1 (permalink)
rainking1978's Avatar
View rainking1978's Photo Gallery
My 03 has a rattle since the old tensioners are garbage, had to purchase the new designed one. Just got this today and plan on installing it this weekend. Any tips. Also, is the tensioner suppose to wiggle a little from the shock part? Also, it has no tension in it?
2009 Honda Civic Si
2005 Corolla CE
2006 ZX10R
rainking1978 is offline   Reply With Quote
Old 10-30-2009, 07:22 PM   #2 (permalink)
View jeff1000's Photo Gallery
Have to look at TSB EG021-07
It's located here:
http://www.z-car.com/lotus/files/200...T-EG021-07.pdf
This should have all the information you need to install the tensioner.
jeff1000 is offline   Reply With Quote
Old 10-31-2009, 01:27 PM   #3 (permalink)
Done. Took about 45 minutes. Take belt off. Remember the pattern. Remove 3 engine bolts, jack the engine up, remove top nut off the tension, remove the long bolt. Put everything back together. Easier then I thought.
2009 Honda Civic Si
2005 Corolla CE
2006 ZX10R
