Originally Posted by Charcrolla
Hey Everyone,
I don't know too much about cars, and I'm new to this site. I know my corolla's thread pattern is 5X100 I know what the 5 means, and I am guessing the 100 is the size of the lug nut? Would a lexus is300 rim fit the corolla?
Thanks!
no, those rims will not fits.
MAKE:Lexus
MODEL:IS 300
YEAR:2001 - 2004
BOLT:5x114.3
OFFSET:34 to 45
MAKE:Toyota
MODEL:Corolla
YEAR:2003 - 2010
BOLT:5x100
OFFSET:35 to 45
Wheel Offset
The wheel offset is the distance from the hub mounting surface to the centerline of the wheel. There are three types of offsets.
Positive Offset
A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the wheel. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or "deep dish".
Bolt Patterns
A wheel's bolt-circle-diameter is the diameter of an imaginary circle drawn through the center of the wheel's mounting-bolt holes. Different vehicle makes and models have varying bolt patterns.
If the pattern has an even number of mounting holes (four, six or eight lugs) simply measure from the center of one stud hole directly across the center of the wheel to the center of an opposite stud hole.
With a five-lug pattern, measure from the center of one stud hole to the center of the farthest stud hole, skipping the adjacent hole. The resulting measurement is slightly smaller than the actual bolt-circle diameter.
For example, a vehicle with a bolt pattern of (5 x 120) means this vehicle's hub has five bolts or lugs, which measure 120 millimeters apart from one another diagonally. Below is a chart on how to measure bolt patterns. Wheelfire.com has a fitment program that calculates this for you.
Five Lug
2011 RAV4 I4 LTD with leather package. Used have 9th Gen Corolla with 2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
