Rims install question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2009, 06:45 PM   #1 (permalink)
05 Rolla
View RawDarkness's Photo Gallery
I went to Sears Auto Center to get my rims and tires put on, they said I need an hubcentric ring or vibrator ring so these will fit snug. Where can I go to get this?
RawDarkness is offline   Reply With Quote
Old 11-07-2009, 07:22 PM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
Whomever sold you your wheels. You need to know the hub size of the wheels you're installing, plus the hub size of the car (which is 54.1mm I think).
One question: do your new wheels use a tapered acorn type lug nut, or a shank type lug nut? If they take a tapered lug nut, you don't need the rings.
JasonA is offline   Reply With Quote
Old 11-07-2009, 07:26 PM   #3 (permalink)
05 Rolla
the new hub bore is 72.7 with the lugs supposed to be 12x1.5 but I am not sure at all what type of lug nuts it needs
Old 11-07-2009, 08:21 PM   #4 (permalink)
on full afterburner
Gameroom cash: $1345597
What type of wheels are they?
Old 11-07-2009, 08:34 PM   #5 (permalink)
05 Rolla
Motegi FF7 5x100
Old 11-09-2009, 11:06 AM   #6 (permalink)
05 Rolla
Will i be needing wheel spacers as well? the wheels say the setup is still OE but not sure if my calipers will be in the way or not. This is my first time ever buying rims so all the help I get is much appreciated
Old 11-09-2009, 11:24 AM   #7 (permalink)
on full afterburner
You will need to list detailed specs, like the wheel size, wheel width and offset in order to determine whether they will clear the brakes or not.
Old 11-09-2009, 11:26 AM   #8 (permalink)
'11 Camry
It looks like the wheels have a 42mm offset. So they should be fine from that regard. I'm still having trouble finding out what type of lug nuts they use. Do you have the wheels (physically)?
Old 11-09-2009, 11:29 AM   #9 (permalink)
'11 Camry
Here you go:
http://www.summitracing.com/parts/ARE-23736717/
The FF7 uses a 60* conical style lug nut. You don't need the hub rings. The wheels will not vibrate on your car as long as you use conical (acorn type) lug nuts. The lug nuts will center the wheel on your hub assembly automatically, as they're tightened down. Just make sure they tighten all the lug nuts in the recommended "star" pattern and that they're torqued properly.
I might take it somewhere other than Sears if they're not familiar enough with this.
And post a picture when you've got 'em on!
Old 11-09-2009, 11:57 AM   #10 (permalink)
05 Rolla
hmm so Sears is just being weird I guess. But then again, they just asked If I had an installation kit with it, I told them no and then they said I "Need" the hub centric rings so it wont vibrate while driving. They took the rims out of the box and just said that flat out without even tryin it now that I think about it. wow, thanks for keeping me in check on that man. I will be calling meineke now
Old 11-09-2009, 12:07 PM   #11 (permalink)
05 Rolla
maybe its best to be safe getting the hub centric rings though... i read that a guy never put them on and one day his front wheel went crazy and flew off
Old 11-09-2009, 01:45 PM   #12 (permalink)
'11 Camry
It all depends on the type of wheel, and type of lug nuts used. Most wheels out there (like your new ones) are lug-centric wheels and the wheel is centered by the lug nuts. As long as those new wheels use a conical seat like the website says, you'll be good to go.
The ring is for wheels that are hub-centric (like the stock Toyota alloy wheels). These wheels use a shank-style lug nut and have no means to center the wheel on the hub besides the centerbore. Replacement wheels often have a larger bore than required, so they can fit multiple types of vehicles...and a ring is needed to take up the space between the small hub on the vehicle and the larger bore of the wheel.
But again, this is ONLY required if you have hub-centric wheels. It appears that your new wheels are lug-centric, and so absolutely do NOT require those rings.
Old 11-10-2009, 12:42 AM   #13 (permalink)
05 Rolla
I ordered the lugs for the FF7 style rims so that way the cap will still cover them as they are meant to be and it also comes with the hub centric ring just in case. But I am taking your advice, as soon as I receive the installation kit I will now know its not required. Thanks for you help
Old 11-10-2009, 06:57 AM   #14 (permalink)
'11 Camry
If you get the ring with the kit, it certainly wouldn't hurt to use it.
Old 11-10-2009, 11:30 PM   #15 (permalink)
05 Rolla
thanks for the help, much appreciated
