No power to the fuel pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2009, 02:57 PM   #1 (permalink)
View pfsrst's Photo Gallery
I have a 2007 corolla. Over the last week has taken longer to start. It would crank but not start. At times 10 min or so. then it would just start. Now won't start at all. I listened for fuel pump sound, nothing. Removed fuel pump from car, bench tested with another battery, the pump seems to work fine. I put it back into car, nothing. It seems the pump is not receiving power. Changed the EFI fuse/relay in the fuse box, nothing. Also just checked for plug spark. None. Has anybody seen this problem before? Can anyone thats had some experience with corolla's help?
Thanks in advance,
Mark
pfsrst2@hotmail.com
pfsrst is offline   Reply With Quote
Old 11-11-2009, 09:58 PM   #2 (permalink)
View tigerclaws1318's Photo Gallery
I'm no expert in electrical but you can take a voltmeter and check the voltage supply from the battery to the fuel pump itself. Also check for damaged wires.
tigerclaws1318 is offline   Reply With Quote
