Corolla 2006 LE: hissing noise on passenger side lega rea - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2009, 01:59 PM   #1 (permalink)
View mbaranov's Photo Gallery
Canada Corolla 2006 LE: hissing noise on passenger side lega rea
Hello!
I just bought a used Corolla 2006 LE, otherwise in top shape. I recently noticed a hissing noise on the passenger side in the leg area. It's not loud, but audible. It comes in as I start the engine and dies when I kill the engine. It does not depend on HVAC settings or engine RPM, always present. I don't hear it under the hood or wheel arch. Engine idles at 800RPM, HVAC is OK, not any other problems.
Is it normal? What could it be?
Thanks!!!
Michael.
mbaranov is offline   Reply With Quote
Old 11-12-2009, 04:16 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Check the cabin air filter face plate.
mikered30 is offline   Reply With Quote
Old 11-12-2009, 06:44 PM   #3 (permalink)
Thanks!
Is there anything specific I need to look for when inspecting it?
Old 11-12-2009, 07:03 PM   #4 (permalink)
mikered30's Avatar
If there is any play in it. It may be beneficial to drive around with the glove box off and see or hear if you can isolate the noise. A passenger might help too.
Old 11-13-2009, 07:29 AM   #5 (permalink)
Does anyone else have it? Could it be a "vacuum leak" in my case?
Old 11-13-2009, 11:15 AM   #6 (permalink)
I checked and cleaned it - nothing wrong with it. The hissing is coming from the that HVAC module over there, behind the glove bar.
Old 11-17-2009, 07:43 AM   #7 (permalink)
Question
I also noticed something else (not sure if it is related to the above). Sometimes, every 3-5 minutes when engine is hot, and idling at the lights, the RPM goes up to 1000 for 4-5 seconds and back to 800, at the same time I can hear a "ps-s-s-s-sh-sh" sound somewhere from behind the dash. The sound is like some excess hot air is released. :-/
I'm puzzled, please HELP!
Old 11-19-2009, 08:10 AM   #8 (permalink)
Hmm... I think I can hear the a/c compressor running in my case. Now the question is why does it run all the time? I have never ever had fog on the inside of my windows, so I assume I have some sort of of automatic climate control system? Some say that A/C kicks in defrost mode (which may be true for me), but for me the compressor works all the time regardless of the HVAC controls...
Old 11-24-2009, 12:38 PM   #9 (permalink)
View ice.izm.inc's Photo Gallery
No big deal. This happens on every corolla. Like someone stated above this has something to do with the cabin filter. Also be sure to check the filter (behind your glove box) every 3months. Sometimes it simply needs to be re-adjusted. Under acceleration you should hear a light hiss.This is normal but you should never hear a knocking noise...that would be the quarters in the cupholder.
ice.izm.inc is offline   Reply With Quote
