Replacing tires & alloys? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2009, 08:50 PM   #1 (permalink)
View Yezinki's Photo Gallery
My Corolla 06 has 195/60/R15 tires & alloys.
I want to change them to high performance alloys & tires.
What should I be looking for/ keeping in mind……..Rim size I want to keep at 15”…..but what brand, weight etc?
Tires for excellent wet & dry grip, traction, braking, cornering etc
How do I calculate?
I know that a wrong selection can lead to false readings on the speedometer.
Hoping to learn & hear your views,
Yezinki.
Pros & cons of goin to 205/55/R15?
Yezinki.
Yezinki is offline   Reply With Quote
Old 11-25-2009, 04:13 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
I moved this thread from another forum and wondered if you all could lend the OP a hand with his wheel and tire questions. Muchas gracias!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-25-2009, 04:27 PM   #3 (permalink)
on full afterburner
Gameroom cash: $1345597
IMO:
Stick with Enkei, SSR, Work and anything from under the Rays Engineering brand.
Stick with the stock size tires or resize them at the http://www.miata.net/garage/tirecalc.html
Play around until you find a tire size that doesn't throw off the speedometer by a lot.
Whereabouts are you located?
Old 11-25-2009, 08:41 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Why 15s? the car would perform and look better with 16s. But yeah, 205/55-15s wider and lower so they handle better than the ballooney original size.
Old 11-26-2009, 03:22 AM   #5 (permalink)
As mentioned earlier it has 195/60/R15”.
1. Increasing the rim size to 16…..better looks agreed……what weight approx…..16lbs alloys?.....besides looks with a 16 what else do I gain....as regards to road grip, handling cornering etc?
2. To correct the speedometer readings error…..tires size to 50 or 55…..205/50-55/R61”?
3. With these new sizes how would the drive be in city, highways & bumps…….pros & cons of this change in the vehicle’s ride pertaining to acceleration, high revining, FC, handling, cornering etc?
Thanks TrailDust, Mr. PhatRoyale & REN69.
REN69 you recommend 205/55/15 or 205/50/15?
Old 11-28-2009, 02:52 PM   #6 (permalink)
impala409's Avatar
View impala409's Photo Gallery
Yezinki...Good Questions! I'm also curious too. Anybody have some answers. Also, how big a wheel/tire can you go before interference with wheelwells, etc?
impala409 is offline   Reply With Quote
Old 11-28-2009, 10:21 PM   #7 (permalink)
Personally performance of any vehicle is my first priority & looks comes after that. As for alloys/rims are concerned would never try going beyond 17”……..alloys should be light weight approx a little over 16 lbs…..more the size & weight adds load on suspension & incorrect Speedo readings……tires good brand, durable, soft…..like Michelin Hydro edge or any reputable brand…..size again max 205-225 width…….cause if combo is incorrect the car might look fancy but many pit falls…….like lower FC, incorrect readings, suspension loads, fender damage…….unless you wanna change & mod suspension too …….as one of the members replied it’s not a sports car but rather a dependable, reliable family commuter.
Just my thoughts.
Old 11-29-2009, 11:23 PM   #8 (permalink)
Originally Posted by PhatRoyale View Post
IMO:
I live in HI....which stands for the state of Hawaii.
Old 12-01-2009, 09:54 AM   #9 (permalink)
on full afterburner
Lucky guy.... parts are very easy to come by there.
Old 12-01-2009, 03:01 PM   #10 (permalink)
So true……..Hawaii is awesome………in all aspects.
Yezinki.
Toyota Corolla 9th Gen 5 speed M/T.
Engine oil-5W-30, Gear oil GL-4 75W-85, Denso SK16R11, Secret Weapon CAI, LI with 2 front standard sensor heads.
BMW 328i
Old 12-01-2009, 09:24 PM   #11 (permalink)
KDM is in
REN69's Avatar
205/50 would be too small for your car, 205/55-15 would be a closer match.
You should play with the tire size calculator online.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 12-01-2009, 09:31 PM   #12 (permalink)
Thanks REN69........what brand H tires .......205/55-15 i'd get a false slower reading by about approx 3 mph?
Yezinki.
BMW 328i
