High idle on cold startup...What's considered normal? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2009, 08:45 AM   #1 (permalink)
View derdeb's Photo Gallery
Hi there,
I just bought a preowned 2004 Corolla S and discovered that's it idle is quite high when I first start it up. It's not too cold here (about -2 Celcius) and I don't know if it's normal or not.
The idle slowly creeps up to about 2600 and then quickly 'resets' back down to 900. This repeats for a while until I put into first (manual transmission) and drive it. After about a minute, it idles at it's normal 800 range.
Normal? In need of a tuneup? New sparks?
derdeb is offline   Reply With Quote
Old 12-07-2009, 09:40 AM   #2 (permalink)
View tigerclaws1318's Photo Gallery
The highest the idle should reach is 2000rpm on very cold days. 2600rpm isn't normal. How many miles on the car? Scan the car for any trouble codes first.
tigerclaws1318 is offline   Reply With Quote
Old 12-07-2009, 12:25 PM   #3 (permalink)
'11 Camry
View JasonA's Photo Gallery
The idle speed hunting like that is not normal. 2000-2200 RPM is about the highest it should idle when cold, and only after a cold start.
JasonA is offline   Reply With Quote
Old 12-07-2009, 04:51 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532067
Any CELs or vacuum leaks?
mikered30 is offline   Reply With Quote
Old 12-07-2009, 05:42 PM   #5 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
Canada
Originally Posted by derdeb View Post
Hi there,
that is not normal, my 08 S start at -10 C, and still not passing 2000 rpm
high idles are caused by either a sticking Idle Air Control valve or a vacuum leak allowing air in somewhere it shouldn't be. Look at the condition of the hoses connected to your engine's intake and replace any that are cracked or split. Also make sure the intake air duct from the air cleaner to the intake is intact. but better plug in OBDII to get codes out
2011 RAV4 I4 LTD with leather package. Used have 9th Gen Corolla with 2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 12-08-2009, 06:18 AM   #6 (permalink)
View dorman68's Photo Gallery
I agree with tigerclaw. My car acted the way you described and it ended up needing an intake manifold gasket, as there was a vacuum leak betweein the manifold and the head, very cheap and easy DIY repair (new intake manifold gasket). Hope this helps.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 12-08-2009, 03:34 PM   #7 (permalink)
View 02zx9r's Photo Gallery
31* past couple of mornings here and when I start mine it goes to 1600rpm and stays there.
2008 Toyota Corolla LE 5-speed
2002 Kawasaki Ninja zx9r
02zx9r is offline   Reply With Quote
Old 12-08-2009, 06:16 PM   #8 (permalink)
View GTurner598's Photo Gallery
reset the ecu and see if that takes car of the problem.
2003 S/C Toyota Corolla S
TRD S/C is now up for grabs!! $1500 for the blower and 2.3 pulley or $3000 for everything needed to boost a 03-04
9GC - FTW!!
GTurner598 is offline   Reply With Quote
