Zeroing formula? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2009, 02:26 AM   #1 (permalink)
View Yezinki's Photo Gallery
Zeroing formula?
http://www.wheelsmaster.com/rt_specs.jsp
My Corolla 06 has OEM tires 185/65/R14….how do I check for zeroing……& which tires sizes should I go for…..since I plan changing the wheels to 16/17”?
Curious to learn how to use this to zero........I mean how does one calculate.........put in the OEM values in the left.... OEM values 185/65/R14 shows 14 X 7 X ET10.........what does that signify & what do I do next?
Pros & cons of reaching a zero value?
Thanks.
Yezinki.
Toyota Corolla 9th Gen 5 speed M/T.
Engine oil-5W-30, Gear oil GL-4 75W-85, Denso SK16R11, Secret Weapon CAI, LI with 2 front standard sensor heads.
BMW 328i
Yezinki is offline   Reply With Quote
Old 12-12-2009, 11:52 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $995375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
185=tire width
65=sidewall hight
R14=Rim Diameter
14=Rim Daimeter
7=Rim Width
ET10=Offset
By Zero Value are you meaning tires flush with fenders?
The Jedi Speeder at CarDomain
Old 12-13-2009, 12:03 AM   #3 (permalink)
MR2Jedi,
What purpose does this calculation serve?
ET10= Offset…….is that bad….should ET be 0?
I plan changing the wheels to 16/17” size………will this http://www.wheelsmaster.com/rt_specs.jsp..........be of any help as to wheels/tires selection if yes than how?
Thanks.
Yezinki.
BMW 328i
Old 12-13-2009, 12:31 AM   #4 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
Are you talking about tire SIZE? If so, run your calculations here:
http://www.miata.net/garage/tirecalc.html
You can pick various sizes and see how they will affect your speedometer readings. For me, I plan to go to a wider size and try to maintain standard readings on my speedo and odometer. I am looking at 215/60/15 for my new tires - should be real close to my factory stock size of 195/65/15, in regards to the speedo readings. I also have 6.5 inch wide aftermarket wheels on my car that should fit these tires pretty well.
Factory revs (of the tire) per mile = 807, new size (215) = 802
Is this the kind of info you are asking about?
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 12-13-2009, 12:41 AM   #5 (permalink)
Not tire size.......wheel/alloy size.
Yezinki.
BMW 328i
Old 12-13-2009, 12:57 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
it's not bad, but probably not your offset. The smaller the the offset value, the more the wheel goes outward towards the fender.
You need to find out what your stock offset is if you want to bring your wheels flush with your fenders-if thats what you're trying to do.
Go 17" x7"rims..
Tires 205/40/17 this will only throw your speedo off about 3mph.(you will be going 3mph faster than your speedo reads.)
Old 12-13-2009, 01:11 AM   #7 (permalink)
OK …….now it's clear.........ideally can never be zero?
This is my stock offset......is it good?
Presently am using 195/60/15"............values again are 15/7/ET=10.......but when I measured these alloys they were 8.25" width, this zeroing calculation shows 7".............strange??................plan to change to 16/17".........will keep both calculations into context.
Yezinki.
BMW 328i
Old 12-13-2009, 01:32 AM   #8 (permalink)
10 is a small or a big value?..........smaller the value e.g 5........ the wheel shall get closer to the fender........am I correct....so hypothetically offset should be more for the wheels to remain away from the fender?
Yezinki.
BMW 328i
Old 12-13-2009, 01:33 AM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Your offset is NOT ET 10. If it were, your wheels would be sticking out beyond the fenders.
For example: My rear wheels on my MR2 have a +35 offset and they are flush with my fenders. The wheels I replaced(aftermarket) had an offset of +40 and they were 5mm inside the edge of my fenders.
So the smaller the ET value, the further out the wheel will be towards the fender.
If you're not concerned about the " flushness", then get wheels with an offset between +38 & +42. Those should be safe and close to your stock offset.
The closer you get your wheels to the fenders, the wider stance you will have and the better handling you'll have. Looks cool too.
Old 12-13-2009, 01:40 AM   #10 (permalink)
185 X65 X 14 …………Offset (ET) =10……….. Width of alloys when measured showed 8.25”, here it shows 7”??
Yezinki.
BMW 328i
Old 12-13-2009, 01:48 AM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Correct.
the larger the value, the more "tucked" inwards from the fender.
Old 12-13-2009, 01:50 AM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Measured by whom/what ?
here it shows 7”??
where?
Old 12-13-2009, 01:51 AM   #13 (permalink)
Why this zeroing formula shows width of the wheel as 7" vs on ground when measured was 8.25"?
Yezinki.
BMW 328i
Old 12-13-2009, 01:54 AM   #14 (permalink)
Originally Posted by MR2Jedi View Post
[/color][/font][/color]
where?
I measured the alloys & the width was 8.25".
Now using this wheel/ tire calculator width displayed is 7"?
Yezinki.
BMW 328i
Old 12-13-2009, 02:01 AM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If the wheels are OEM, they are not 8.25" wide. They are 7".
Measurement must be incorrect. Width is measured fron the inner edge .Not the outer edge.
