Low end torque loss why so late? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2009, 12:21 AM   #1 (permalink)
View Yezinki's Photo Gallery
I have had this 9th Gen Corolla since 06, presently done about 13K.
Always used Toyota mineral based engine oil till now.
Replaced stock intake in 07………no issues……no codes etc.
Since I switched to fully Synthetic engine oil I feel the engine asking for the next gear at an earlier rpm.
Previously I switched to 5th at about 65mph, now at 40mph.
What could the possible reasons be……….engine not used to fully synthetic taking its time ……….since it’s just only 200miles after the oil change?
From here start all issues.
Hoping to hear your experienced comments.
Thanks.
Yezinki.
Toyota Corolla 9th Gen 5 speed M/T.
Engine oil-5W-30, Gear oil GL-4 75W-85, Denso SK16R11, Secret Weapon CAI, LI with 2 front standard sensor heads.
BMW 328i
Yezinki is offline   Reply With Quote
Old 12-13-2009, 01:09 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $995375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
If you were experiencing some type of torque loss, you would have to shift later, not sooner.
Do you have a Tachometer in your gauge cluster? If so, you should be changing gears according to it.
Find you optimum shift points( where you hit your highest torque in each gear)
Synthetic oil may make your engine rev up alittle faster having less friction. Not sure that it would be noticeable though.Like I said, I'm no expert.
The Jedi Speeder at CarDomain
Old 12-13-2009, 01:22 AM   #3 (permalink)
[/quote]
1. OK.
2. Yes I do have a tachometer in the gauge cluster.
3. If I understand correctly meaning streching a gear bit more?
4. Idle start it revs a bit more but normal city driving as stated earlier wants the next gear earlier, at a lower rpm & speed.
Thanks shall keep you informed.
Yezinki.
BMW 328i
Old 12-13-2009, 01:38 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yes, but depending on where your shift points are. At what RPM's do you change each gear?
Old 12-13-2009, 01:44 AM   #5 (permalink)
I never really checked but I think 1.5, 2, 3, 4.
But when I rev..........6, 6 again & than straight to 5th lol.
Yezinki.
BMW 328i
Old 12-13-2009, 01:53 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I don't understand?
Do you have a 6 speed trans?
Old 12-13-2009, 01:59 AM   #7 (permalink)
Sorry for that.
I have a 5 speed.
1.5K RPM for 2, 2K RPM for 3, 3K RPM for 4, 4K RPM for 5th.
6K RPM for 2, 6K RPM for 3 & than directly to 5th.
Yezinki.
BMW 328i
Old 12-13-2009, 02:54 PM   #8 (permalink)
View GTurner598's Photo Gallery
i am really confused here. in normal driving you should shift at like 3,000 RPM but when you are going WOT and want power you wanna rev it all the way up. When im pushing it as far as it can go, i got to 7,200 RPM thanks to a removed rev limiter.
2003 S/C Toyota Corolla S
TRD S/C is now up for grabs!! $1500 for the blower and 2.3 pulley or $3000 for everything needed to boost a 03-04
9GC - FTW!!
GTurner598 is offline   Reply With Quote
Old 12-13-2009, 04:05 PM   #9 (permalink)
GTurner598 is your Corolla auto or stick shift?
Yezinki.
BMW 328i
Old 12-13-2009, 04:22 PM   #10 (permalink)
i am a 2003 Corolla. Supercharged and a 5 speed with a built tranny.
9GC - FTW!!
Old 12-13-2009, 04:30 PM   #11 (permalink)
Thanks GTurner598,
Could you care to list of mods for performance for a 1ZZ-FE starting from the simple/basics to advanced……..I know you would firstly ask, would you want it charged or N/A…….can 1ZZ-FE engine internals handle 8plus psi…..if not than N/A?
Yezinki.
BMW 328i
Old 12-13-2009, 08:46 PM   #12 (permalink)
'11 Camry
View JasonA's Photo Gallery
You should be able to feel no difference between synthetic and conventional oil in terms of when the engine wants to shift. During normal driving, here's when I shift:
1-2 shift: 10-15 MPH
2-3 shift: 25-30 MPH
3-4 shift: 35-40 MPH
4-5 shift: 40-45 MPH
Letting it rev any higher than about 2500 RPM gets wasteful, if you don't need the power. The engine has good low-end torque for a 4-cylinder.
An easy way to remember shift points is going by RPM if you like. For economy, keep the engine under 3000 RPM. Around 2500 RPM is a good shift point, assuming your car is geared the same as a North American car.
JasonA is offline   Reply With Quote
Old 12-14-2009, 03:22 AM   #13 (permalink)
JasonA……I normally shift according to the feel on the gas pedal & sound of the engine…& not looking much at either the speed or RPMs……..you gotta nice signature……..1 US Gal = how many IMP Gal & Ltrs?
Hello MR2Jedi,
How do you rate this exhaust setup……….. http://www.magnaflowplus.com/showite...-Back%20System
1. Is it good enough?
2. Will it be able to handle this turbo kit for 1 ZZ-FE………. http://www.turbo-kits.com/corolla_turbo_kits.html
3. Could you care to answer a few noob questions about it.
a. Is it a reliable one or any better for 1 ZZ-FE.
b. Can I use my preferred air filter & Piggy back rather than K & N, Hydra & AEM?
c. What approx max WHP can I expect to get from it….stock 1 ZZ-FE is approx 100 plus WHP & I think 136 HP ……..Torque 171Nm@42K RPM.
d. After market vs. OEM turbo………what turns the turbo on & shuts it down?
e. Any stock engine internals that would need to be forged?
I shall keep bothering you hope you don’t mind it.
Regards.
Yezinki.
BMW 328i
Old 12-14-2009, 11:07 AM   #14 (permalink)
intake, header, catback, lightweight pulleys, underdriven pulleys, camcon, emanagle blue, emanage ultimate, grounding kit, shortshifter, lightweight wheels, lowering springs, coilovers, colder plugs, thats a quick list that i can think of while im at work but there is alot that can be done to help free up some power
9GC - FTW!!
Old 12-14-2009, 09:18 PM   #15 (permalink)
Hello MR2Jedi,
Comments needed.
Thanks.
Yezinki.
BMW 328i
