Need help quick!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2009, 10:14 PM   #1 (permalink)
View addiction41999's Photo Gallery
Need help quick!!
I need to remove the starter out of my 2005 Corolla. Need help if you know how to do. Should be relatively easy no?
Thanks everyone!!!
addiction41999 is offline   Reply With Quote
Old 12-16-2009, 06:14 AM   #2 (permalink)
'11 Camry
View JasonA's Photo Gallery
It's two bolts and two wire connections. Be sure to remove the negative battery cable first!
JasonA is offline   Reply With Quote
Old 12-16-2009, 09:20 AM   #3 (permalink)
View dorman68's Photo Gallery
From alldata, hope this helps.
REPLACEMENT
  1. DISCONNECT BATTERY NEGATIVE TERMINAL
  2. REMOVE ENGINE UNDER COVER RH
  3. REMOVE ENGINE UNDER COVER LH
  4. REMOVE STARTER ASSEMBLY
  1. Disconnect the starter connector.
  2. Open the terminal cover.
  3. Remove the nut, then remove the starter wire.
  1. Remove the 2 bolts, then remove the starter.
    1. INSTALL STARTER ASSEMBLY
  1. Install the starter assembly with the 2 bolts. Torque: 37 N.m (378 kgf.cm, 27 ft.lbf)
  1. Install the starter wire with the nut. Torque: 9.8 N.m (100 kgf.cm, 7 ft.lbf)
  2. Put the terminal cover.
  3. Connect the starter connector.
    1. INSTALL ENGINE UNDER COVER LH
    2. INSTALL ENGINE UNDER COVER RH
    3. CONNECT BATTERY NEGATIVE TERMINAL Torque: 5.4 N.m (55 kgf.cm, 48 in.lbf)
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 12-16-2009, 10:02 AM   #4 (permalink)
Talking Thank You!!
You guys are amazing. Woke up wondering if I'll be able to do this and now I'm excited as hell to take this thing apart. I'm on my way to do some damage.
Thank you again!
Old 12-16-2009, 03:57 PM   #5 (permalink)
Update...
Took out starter, got new one, reinstalled...
vrrooom!! Good to go. Thanks again!!
I owe you guys one!
Old 12-16-2009, 05:34 PM   #6 (permalink)
'11 Camry
Cool! Easy job, huh? Glad you're movin' again.
