MIL Light on, have Freeze Frame Data
P0171 light is on and stays on (even when warmed up). 2005 Corolla CE, 104,000 km, no parts replaced (the ECU was reflashed at 35,000km and successfully corrected the RPM hunting).
I did a lot of reading and see all the suggestions (and TSB's), however before I start replacing parts how can I use the freeze frame data to help narrow the cause?
I also saved 20 frames of live data triggered manually (after no special event).
Here's what jumps out:
FF Data shows PID "Bank 1 - Sensor 1 O2S voltage" of between 3.98 & 4.01 - is this too much?
The Bank 1 - Sensor 2 voltage is within specs (at 0.05V), but I can't find the specs for B1S1.
Just looking for advice on properly reading this data.
Thanks.
