03 corolla new f/brakes squeal at 40 up
I replaced my front pads, calipers, turned rotors and bled the brake system 4 months ago. Brakes worked fine for 2 months then started squealing when pressing brake gradually at 40 mph or higher. I thought this would go away after they wore in. NO dice! I took the pads off and regreased the shims and tightened the metal holders. NO dice. I then pulled the rotors off cleaned them up with cleaner and cleaned regreased shims again, NO dice.
This week ended I swapped out the pads for some new ones and the squeal is gone. Those pads must have been made with to much metal in them. Oreilys best pads. What a pain in the butt.
