Engine RPM oscillates/fluxuates after cold start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2010, 10:24 AM   #1 (permalink)
View lebe0024's Photo Gallery
When I cold start my car, the engine idles high around 2000 or so (like normal). Then after a minute or so the RPMs start dropping to 1000 then climb back to 2000. It does this for a couple minutes until the car warms up. Each climb sequence takes about 2 seconds. So the sequence is:
1. start car
2. idle at 2000 for a minute or so
3. quickly drops to 1000, then climbs from 1000 rpm to 2000 rpm over 2 seconds
4. repeat step 3 until car is warm. idles at normal low speed.
It's a 2003 Corolla CE and I don't have any engine/warning lights on. I don't experience any other problems driving the car. Is this what they call idle hunting? I thought it might be related to the TSB about the intake manifold gasket, but that TSB seems to say your MIL will come on.
Cold weather idling issue: Tach bounces up and down
Any help is appreciated!
lebe0024 is offline   Reply With Quote
Old 01-12-2010, 06:02 AM   #2 (permalink)
View dorman68's Photo Gallery
Sounds like an intake manifold gasket, fairly common issue on the 9th gen 1zzfe Corollas. The rubber gasket shrinks when it's cold and causes a vacuum leak, as the engine warms up the gasket expands and the vacuum leaks go away. A fairly easy DIY fix, the gasket is about $10.00. I have helped a couple of people with this fix. Hope this helps.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-16-2010, 07:02 AM   #3 (permalink)
View Bucker's Photo Gallery
MIL light will eventually come on if it is the intake manifold gasket. My car experienced idle hunting for 3 winters before MIL came on. And yes it was the gasket that doesn't cost $10.
Bucker is offline   Reply With Quote
Old 01-16-2010, 06:10 PM   #4 (permalink)
View atifkm's Photo Gallery
Where is the intake manifold located. Is it a small job. Does it requires anything else than gasket.
atifkm is offline   Reply With Quote
Old 01-16-2010, 07:14 PM   #5 (permalink)
TSB link below will show you where it isand what it takes to replace:
http://ww2.justanswer.com/uploads/sk...rolla_0171.pdf
Old 01-17-2010, 10:36 AM   #6 (permalink)
View tarbasd's Photo Gallery
Can't you get away from draining the coolant? Because that makes it more expensive, if you don't want to reuse the same coolant.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
Old 01-17-2010, 11:20 AM   #7 (permalink)
mikered30's Avatar
Gameroom cash: $532067
If you change it while the car is cold you do not have to remove the coolant lines, just remove the throttle body from the intake manifold. You will need another throttle body gasket as they are not reusable.
mikered30 is offline   Reply With Quote
Old 01-17-2010, 03:42 PM   #8 (permalink)
I see. I think I'll have to do this soon. I have some minor fluctuation of idle speed when it is cold outside (<35), but it hasn't occurred to me until this last cold wave that it can be a malfunction. It had never really gotten cold here in SC, but I'm moving to Kentucky next fall.
Old 03-16-2010, 12:00 PM   #9 (permalink)
Great! Thanks for all your help guys. A couple more questions:
1. How can I tell if my engine is a 1ZZ-FE?
2. What is involved in replacing your coolant? Do you know how to dispose of the old stuff?
