Where is the fuel filter on my 2007 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2010, 01:19 PM   #1 (permalink)
View gsmeljr's Photo Gallery
Anyone know where the fuel filter on my 2007 CE is located? Thanks!
gsmeljr is offline   Reply With Quote
Old 01-12-2010, 01:56 PM   #2 (permalink)
ems
View ems's Photo Gallery
It's in the gas tank. It's not an item you are supposed to service.
ems is offline   Reply With Quote
Old 01-12-2010, 02:20 PM   #3 (permalink)
OK. Thank you. Does this mean that it never needs replacing, or in the some kind of dealer service only job?
Old 01-12-2010, 02:47 PM   #4 (permalink)
ems
I think it never needs replacing but, I'm not sure.
Old 01-13-2010, 06:16 AM   #5 (permalink)
View dorman68's Photo Gallery
Yep! non-serviceable
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-13-2010, 09:38 PM   #6 (permalink)
View iCorollaS03's Photo Gallery
you replace it with the fuel pump assembly as a whole if your fuel pump breaks down.
iCorollaS03 is offline   Reply With Quote
Old 01-10-2012, 03:10 PM   #7 (permalink)
View spinfisher's Photo Gallery
Thanks, that's an item that has been bvothering me for awhile. So ,, I can just check that off my things to do!
spinfisher is offline   Reply With Quote
Old 01-13-2012, 01:31 PM   #8 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
Technically there is a filter but it mounts to the bottom of the fuel pump and it doesn't need to be replaced as maintenance.
I suppose if it would make you feel better you can remove the fuel pump and replace it but if you're not having any problems with the car then there's no need to bother with it.
If you ever replace the pump assembly it should come with a new filter already installed.
MasterTecInSTL is offline   Reply With Quote
