Originally Posted by cowboycorolla
I drive a 04 Corolla 105K miles, i had my transmission fluid flushed at jiffy lube at about 50K miles... and recently i have been feeling that when driving on a highway at 70 MPH my RPM stays constantly at 3 if i go down to 60MPH it will go to about 2 - 2.2 RPM. However, if i go from 70MPH to 90MPH the gear does not shift, it stays at 3 - 3.5 RPM... Is this Normal???
well first off i would get a tanny flush if anything then see if the problem persists....... then all it could be is a part slowly wearing out that most likley can be replaced...... my corolla is normally in 3rd at 40 unless im driving REALLLY slow then it goes into 4th...... but then again i am an agressive driver..... and noted i forgot where i reseached it.... the 1zz-fe( engine in the s or below models, not the xrs) can run indefinatly at 4000 rpms without damaging the engine if the car is at normal operating temprature.... just as a little bit of info there.......
ohh adn if you take care of your car , you will eventually ahve it so long youll get bored of it lol...... darn corollas lasting till your childrens, children can drive them!!!! lol
2012 if the ft-86 comes out im getting that and the corolla will stay in the garage for long trips lol....... ft-86 outside... i love my corolla too much lol......
ohh and for the car not shifting the cutoff points are at 30,70, and 105 if im not mistaken....... from 2nd to1st, 3rd to 2nd, and 4th to 3rd respectivly...... so if you give it enough gas it should shift from 4th to 3rd at 70mph.....
